Author Topic: [GB]NIZ duo82 - 75% EC Keyboard  (Read 14611 times)
Offline Nizkeyboard
    • nizkeyboard
« on: Thu, 13 May 2021, 01:26:00 »
Hello, From the first IC to the GB, NIZ DUO82 has undergone three design changes and three protype. let's see what the final DUO 82 looks like
Due to the process coating, there are various color choices for DUO82. Also we make 2 designs for this case. There are A and F styles (decided by vote).
In the following pictures, only one color can be selected for the yellow part and one color can be selected for the purple part (not supported different colors). That is to say, the part with the same color in the picture only supports the overall change, and other colors can be matched freely
I must also explain one small parts, which is actually the key parts of duo82 to achieve Bluetooth. During our assembly and testing, we realized this bezel with more choice can show us more fun.so,each duo82 Suite contains 3 such parts, respectively:Black AS, Transparent AS, Brass (same color as other Bezel)
1 Basic Information.
   1   Typing Angle: 6°
   2   Case options:
   Aluminum: Black, purple,  Yellow, White, Blue,pink,orange
   PC: white frosted
   3    Weight options:
   Brass: Black, purple,  Yellow, White, Blue,pink,orange
   4   Plate options
     Brass:Black, purple,  Yellow, White, Blue,pink,orange
     FR4:Black with gold trim, White with platinum trim
    *Plates are 1.5mm thick
   5   Stabilizers
    Choice of:
    1 Costar stabilizers
    2 Cherry-style plate-mount stablizers
   *Each plate will be cut to support only one style of stabilizers
   6  Plate mounting system: Top mount
   7  PCB: NIZ EC PCB with type-C daughterboard,NIZ firmwire support
   8  Battery: 5000mah
   9  Keycaps: compatible with all heights of Cherry MX-style keycaps
  10  Domes: 35g/45g/50g/60g/65g
  11  Layout:
       75% layout
       1.75u Right Shift
       1u Right Ctrl, Fn, and Alt
       6.25u Spacebar
2  GB information
   1 Launch Date:2021.05.15(Beijing time 8:00),https://www.nizkeyboard.com/collections/duo-82/products/gb-duo82?variant=39744345702574
   2 Group Buy duration:the group buy will run for 7 days or until orders reach 200 units
   3 Shipping estimate:within 3 months after the close of the GB
   4 Price:basic kit 350usd(Paypal fee included)➕shipping( depends on destination )
          Wired suite:+135usd
          Bluetooth suite:+179usd
          BLE&RGB suite:+249usd
             All suite are updated with new version  0601)
          Additional EC switches:sliders+switches(100pcs)+25usd
          Additional domes:+30usd(84pcs)
3 Pics
For further information,pls join:https://discord.gg/fKdrR8Manj
update history:
2021.5.13 GB post
« Last Edit: Fri, 14 May 2021, 00:32:17 by Nizkeyboard »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB]NIZ duo82 - 75% EC Keyboard
« Reply #1 on: Thu, 13 May 2021, 08:56:18 »
approved
Offline KVLT
« Reply #2 on: Fri, 14 May 2021, 06:49:11 »
Looking sharp!
the bad guy wins in this one
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
« Reply #3 on: Fri, 14 May 2021, 12:44:07 »
 :eek: love it
Offline stein3
« Reply #4 on: Fri, 14 May 2021, 15:09:01 »
I will definitely be picking one of these up, I just wish the colors were a bit more muted.
Is there any way to pick up multiple accent sets?
edit: I'm silly, I was only looking at the quick order page, but of course there are separate pages for the individual components :)
« Last Edit: Fri, 14 May 2021, 15:32:28 by stein3 »
Offline menuhin
« Reply #5 on: Fri, 14 May 2021, 17:08:17 »
Would like to know more about the capability of NIZ firmwire e.g. how it compares to VIA, QMK / TMK, like key configuration possibility and ease of usage.
Hope we can see these info somewhere on the NIZ website, e.g. in FAQ or under the firmware page.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Nizkeyboard
    • nizkeyboard
« Reply #6 on: Sat, 15 May 2021, 00:39:58 »
ths advise
Offline pixelpusher
« Reply #7 on: Sat, 15 May 2021, 01:12:43 »
Can you mix A top with F bottom?
Offline hcoopos
« Reply #8 on: Tue, 18 May 2021, 16:59:34 »
Yep, you can mix A and F top/bottom
Offline stein3
« Reply #9 on: Tue, 18 May 2021, 17:57:17 »
Got one in Poly. Can't wait!
Offline Liub
« Reply #10 on: Wed, 19 May 2021, 03:56:16 »
A bit confused with the items on the website :(. Does the BLE suite come with 5000mah battery? Or only the BLE+RGB? I don't want RGB, but would like a bigger battery.
Offline Keybadger
« Reply #11 on: Sat, 22 May 2021, 12:12:10 »
It comes with a 2500mah if you choose the BLE or BLE+RGB, its a separate item listed on their site for the 5000mah battery, its $15 https://www.nizkeyboard.com/collections/duo-82/products/gb-duo82-battery-5000amh
Offline menuhin
« Reply #12 on: Fri, 11 June 2021, 05:01:27 »
ths advise
An example firmware comparison page:
ZMK firmware https://zmk.dev/docs/
IBM M13 black
HHKB Pro 2 HasuBT
