Author Topic: (PCB) Key not Actuating? Possibly Broken Pad? Any help appreciated.  (Read 1472 times)
Offline fiction12
Hi guys, I've been working with this PCB and found that my left shift was not actuating when pressed. After a long time troubleshooting, I'm pretty sure the solder pad is broken and I need to bridge the connection, but I'm not sure how. When I connect the pads to others from the same/different rows + columns, I get varying results. Could anyone help me with this? Thank you.
« Last Edit: Fri, 14 May 2021, 02:57:10 by fiction12 »
