Author Topic: QMK tap/hold  (Read 4229 times)
Offline frew
    • blog
QMK tap/hold
« on: Mon, 17 May 2021, 00:10:39 »
Hello!
I just built a corne and flashed it with QMK.  I am trying to set it up similar to how I have my homebound ergodox, which means mapping (eg) a to a when tapping and a layer push when holding.  I see docs in QMK mentioning similar functionality, but aside from defining tapping term (one way or another) I don't really see how to use it.  Is there a way to do this with QMK?  Are there examples anyone can link me to?
Thanks either way!
(written on my WIP corne!)
Offline gh_pp
Re: QMK tap/hold
« Reply #1 on: Mon, 17 May 2021, 00:50:33 »
If you program your own QMK, you can do anything, just check their docs
If you use QMK configurator
https://config.qmk.fm/#/tkc/candybar/lefty/LAYOUT
check the Quantum tab, the LT0, LT1 are probably what you want.
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
