Author Topic: PCB, and soldering  (Read 1576 times)
Offline damnboi
PCB, and soldering
« on: Wed, 19 May 2021, 10:04:59 »
Hi, im quite new to the community my mechanical keyboard community, my mechanical keyboard has some problems, when i haven't soldered it and tried it with a tweezer it works fine, but when i solder the switch they don't work, I don't know if it's because of the solder or the switch, hope yall can help me out
Re: PCB, and soldering
« Reply #1 on: Wed, 19 May 2021, 12:03:08 »
Have you tried using tweezers on the problem switches after soldering?  It's possible you have a bad switch or two, it's also possible (though rare) to overheat a pad while soldering disconnecting it from the trace.
If the tweezers don't work post a pic of the PCB and if it's not obvious say what it is (so I can see what should be connected to what in the firmware)
