Author Topic: [IC] CosmiCat Deskmats  (Read 3389 times)
Offline Aiwanei
    • ThocKeys.com
« on: Thu, 20 May 2021, 08:14:02 »
Hello,
This is Aiwanei from ThocKeys.com and we are working on a series of cat deskmats, the first of which is the CosmiCat (a play on Cosmic and Cats, since these are Cats in Space) series.  We wanted to get some feedback on some design variations as well as see how much interest there was overall.
Here are some of the possible designs:
All offered designs will be available in the purple and the blue background options.
These will be offered in 900x400x4mm and possibly another size or two IF there is interest, but any option will be 4mm thick.
Here are some photos of some samples I received from the manufacturer (it's the same manufacturer that other major vendors use).
I'm not the greatest photographer, the images came out a bit more vibrant than what I see, but the mat background came out more vibrant than in the designs:
I would appreciate it if you could fill out my interest check form:
We have a Canadian Proxy and UK Proxy, and I will be the US Vendor.  We are looking for regional vendors for other areas as well.
Thank you for your time.
ThocKeys.com
Offline yoniwolf1202
Re: [IC] CosmiCat Deskmats
« Reply #1 on: Thu, 20 May 2021, 08:45:21 »
Yessss love these, can't wait.
GLWIC <3
Offline MIGHTY CHICKEN
« Reply #2 on: Thu, 20 May 2021, 10:29:26 »
V cute
