Author Topic: Squeezebox Keyboard  (Read 2956 times)
Offline wolfv
Squeezebox Keyboard
« on: Fri, 21 May 2021, 00:23:33 »
Interesting keyboard:
https://peterlyons.com/problog/2021/04/squeezebox-keyboard/
One finer can simultaneously press finger-tip and finger-pad combo.
« Last Edit: Fri, 21 May 2021, 07:57:21 by wolfv »
Offline fpazos
Re: Squeezebox Keyboard
« Reply #1 on: Fri, 21 May 2021, 01:08:29 »
Saw it. Interesting but the lack of keycaps.... Similar concept to datahand
Enviado desde mi Redmi Note 7 mediante Tapatalk
Offline Gorbon
« Reply #2 on: Fri, 21 May 2021, 04:09:55 »
Very interesting concept with lots of good choices, but I'm also not convinced that the lack of keycaps is a good idea.
The key surface area is now significantly reduced (~3x smaller?), which means that you need much more accurate finger movements (with your hands practically locked in place), hitting a surface that was not designed to be fingertip friendly.
I can't imagine how this can be comfortable over longer typing sessions.
Offline nevin
« Reply #3 on: Fri, 21 May 2021, 07:53:38 »
i like the choices for construction and adjustability.
similar to the dmote i saw a while ago.
