Author Topic: 75% PCB with bluetooth?  (Read 1825 times)
Offline arcadeperfect
« on: Mon, 24 May 2021, 09:44:25 »
And, preferably, hot swappable.
Does such a thing exist? All I can find is the Keychron K2 hot swap (sold out and in any case I'd prefer a custom) and the GK84 (long gone). What I really want is a bluetooth PCB in the YMDK acrylic case:
https://ymdkey.com/products/ymdk-84-kit-cnc-acrylic-case-anodized-plate-underglow-rgb-fully-programmable-pcb-stabilizers-for-75-84-keyboard-ansi-iso-layout
But it doesn't seem like that's possible at all.
Any help appreciated!
Offline Hamptonn
Re: 75% PCB with bluetooth?
« Reply #1 on: Mon, 24 May 2021, 16:51:40 »
Are you sold on 75%? There are a ton of TKL kits with bluetooth radios available on aliexpress.
You could use an external converter - http://handheldsci.com/kb/
I've also seen a few USB > Bluetooth conversion tutorials if you can find the right board and you're up to the task. One's linked below
Filco Majestouch 2 Convertible, Zeal v2 62g lubed & filmed, Modded stabs, SA Snowcap
« Reply #2 on: Mon, 24 May 2021, 19:57:59 »
Ha I am kind of obsessed with 75% yeah. Don't ask me to explain it. Thanks for the suggestions though!
