Author Topic: [GB] GLITCH X FROST TKL (215$+) // +PBT FROST (80$) // +DESKMATS  (Read 12012 times)
Offline ectoplasmatic
GLITCH X FROST
Stacked Acrylic & Polycarbonate Mysterium
GB DATE - MAY 28 - JULY 7, 2021
INSTAGRAM | WEBSITE | DISCORD
Live your sci-fi cyberpunk fluorescent dream with GLITCH.
Breathe in crisp and fresh mountain air with FROST.
You can have it either way, or both.
An all CNC stacked plastic case with CNC milled polycarbonate bottom. Silicone sandwich mount, custom silicone pad foot.
All built to house a beautiful silkscreened PROTOZOA PCB, or a CFTKB.com Mysterium PCB of your choice.
Each GLITCH kit contains:
GLITCH Top Layers - CNC acrylic (3)
Polycarbonate Plate - Frosted - ANSI + ISO (universal)
Silicone PCB Mount Sheet (Clear)
Polycarbonate Base Unit - Black Smokey
Stainless Steel Badge
Custom Hardware - Black
Silicone Foot - Black
Custom Carrying Bag
Protozoa Microfiber Cloth
Each FROST kit contains:
FROST Top Layers - CNC Polycarbonate (3)
Polycarbonate Base Unit (Frosted Clear)
Custom Hardware - Gray
Silicone Foot - White
Custom Carrying Bag
Availability
GB Date: May 28th - June 28th
Delivery: 6 months
MOQ 100 units each style
Unlimited group buy
Pricing
+ GLITCH X FROST Kit: $215
+ GLITCH X FROST Top Layers (to mix and match: $60
+ FR4 Plates (ISO, ANSI Dedicated // Black or White): 30$
+ Polycarbonate Plate (universal): 30$
+ P.01 Through Hole PCB: 75$
+ P.01 ULTRA PCB - Solder // Black or White: $50
+ P.01 ULTRA PCB - Hotswap // Black or White: $60
Modding
+ Plate files will be available to cut for yourself (DXF)
+ Top layers (3) files will be available to cut for yourself (DXF, STEP)
Deskmats
Kicking off the 'Protozoa Artist Series' Deskmats comes a commission from artist Tim Evans (IG: @tevans_1022).
The brief was simple - GLITCH - and the artist attacked it in his signature style.
Crank up the brightness in your space with this original design.
Size: 900 x 400mm
Thickness: 4mm
Top Material: Cloth
Bottom Material: Rubber
PBT FROST
Companion keyset made by GEEKARK
MORE INFO HERE
Vendors
USA & UK: Protozoa
EU: KeyGem
Oceania: Daily Clack
Canada: AlphaKeys
Asia: zFrontier EN
China: zFrontier CN
SEA: **PBT FROST & Deskmats only, will be online midnight singapore time (29th) at HEX Keyboards
PCB Info:
1
'Original' P.01 Mysterium PCB
Components: Through-hole, solder yourself
Switches: solder yourself
Silkscreen (on PCB print): Protozoa Swirl
LED Underglow: no
Layout Support: ISO, ANSI, split left & right shift, split backspace, and tsangan and standard bottom row
Colours: Black, White
Cost: 75$ (incl. components)
2
Components: pre-soldered SMD components
Silkscreen: Protozoa Swirl
LED Underglow: yes
Colours: Black, White, SE
Cost: 50$
3
Switches: hotswap, no soldering
LED Underglow: yes
Layout Support: ANSI, standard bottom row
Cost: 60$
Thank you for your support, comments, feedback, interest, disinterest, enthusiasm - everything.
The Protozoa Team (Ecto, Sailer, Hunter) + ULLIAM
« Last Edit: Mon, 28 June 2021, 12:09:55 by ectoplasmatic »
Offline mvkb
  • Designer
    • MVKB
Re: [GB] GLITCH X FROST TKL (215$+) // +PBT FROST (80$) // +DESKMATS
« Reply #1 on: Sat, 29 May 2021, 15:29:15 »
Copped the Frost TKL with a white PCB and Frost PBT. GLWGB!!
Offline g_hack_it
« Reply #2 on: Sun, 30 May 2021, 07:01:04 »
Cannot wait for this. Copped GLITCH with a black pcb and that psychedelic deskmat. One of the most unique designs I've seen around here, was a must-buy for me.
Sent from my LM-V600 using Tapatalk
« Reply #3 on: Sun, 30 May 2021, 12:33:49 »
<3 thanks so much my friend
Offline BaronLaw
« Reply #4 on: Sun, 30 May 2021, 17:36:33 »
 I got the Frost keyboard and keycaps. Looking forward to receiving these. The design of this keyboard had me immediately. I'm very much a fan of the TKL format.
Wishing you success in this endeavor.
« Last Edit: Sun, 30 May 2021, 17:39:25 by BaronLaw »
Offline JDPJHC
« Reply #5 on: Sun, 30 May 2021, 18:44:01 »
Do you happen to know the dimensions and the weight of this keyboard? And what about the angle of tilt on the keyboard? Seems weird that none of these things would be included :/
« Last Edit: Mon, 31 May 2021, 10:24:04 by JDPJHC »
Offline nevin
« Reply #6 on: Sun, 30 May 2021, 21:22:02 »
These look absolutely fantastic! Nice work!
Offline KVLT
« Reply #7 on: Mon, 31 May 2021, 02:16:23 »
i was wishing you took paypal as payment.... i'm over extended on keeb stuffs already.... but damn'd if i don't keep hovering over this frost board.....
the bad guy wins in this one
Offline EightDiagram
« Reply #8 on: Mon, 31 May 2021, 09:21:26 »
Pulled the trigger on FR0ST.❄  Merry xmas! 🎄
Offline SirMehr
« Reply #9 on: Tue, 01 June 2021, 12:38:49 »
Copped a Glitch. Can't wait for this board!
Offline Art4Tech
« Reply #10 on: Tue, 01 June 2021, 13:55:59 »
So glad I could get in on this kit! Thank you! :thumb:
Offline itsazly
    • website place
« Reply #11 on: Tue, 01 June 2021, 15:31:38 »
Not a TKL form factor person; however, my husband is.
Merry Christmas to him, lmao.
Snagged Glitch w/ the Ultra PCB. Super stoked!
Offline nevin
« Reply #12 on: Tue, 01 June 2021, 15:53:39 »
.... lucky guy.
Offline PancakeGoon
  • *•° tape hiss *•~
    • goonf!sh.beets~
« Reply #13 on: Wed, 02 June 2021, 03:18:20 »
Oh man, oh man, oh man...
So my little Core 40 bit the dust a couple days ago when my 1-Year Old decided to see how far he could throw it, so I'm in the market for a replacement board anyway. Was looking for a nice open-component & compact-ish build, but this'll do.
As it just so happens, I also grabbed a small handful of KAT Cyberspace sets just last month ... 🙃
It was meant to be...
Offline RoyalOak88
« Reply #14 on: Wed, 02 June 2021, 11:27:32 »
Is there any way to have an extra Silicone PCB Mount Sheet, so that you can easily swap in the Top layers with the matching PCB?
Offline SuperBaseball
« Reply #15 on: Wed, 02 June 2021, 22:34:49 »
The only thing I’m undecided on is the PCB to go with frost. I already have a white Mysterium so I was thinking the black ultra for a bit of contrast. I’m having trouble visualizing it though and I don’t want to throw off the vibe as it seems you guys color matched throat/white . Any chance of further renders?
Offline nevin
« Reply #16 on: Wed, 02 June 2021, 23:57:50 »
they are just reversed (black & white flipped)
269713-0
something like..... ish
... just using the images in this thread.
« Last Edit: Wed, 02 June 2021, 23:59:42 by nevin »
Offline Zurg Eon
« Reply #17 on: Sun, 06 June 2021, 07:17:37 »
Excited for this! Hoping either GMK Wavez or Nuclear Data will match the Glitch nicely, but we'll see.
Offline RoyalOak88
« Reply #18 on: Mon, 07 June 2021, 04:54:25 »
OP can you give an answer on this please?
Offline dudewth
« Reply #19 on: Mon, 12 July 2021, 00:51:26 »
Is no LED support confirmed for solder ultra PCB? Was hoping to do UV LED + nightwalker switches.
