Author Topic: Can I Buy a Bare Bones Keyboard?  (Read 3288 times)
Offline Zllen
« on: Sat, 29 May 2021, 18:17:46 »
Is It Possible to buy a keyboard without the switches or caps? Specifically a varmillo
Offline MIGHTY CHICKEN
Re: Can I Buy a Bare Bones Keyboard?
« Reply #1 on: Sat, 29 May 2021, 18:20:51 »
Most boards are sold without switches or caps or stabs. Varmillo seems highly unlikely, check out their website though, I remember they were doing some custom stuff though
Offline HungerMechanic
« Reply #2 on: Sat, 29 May 2021, 18:35:45 »
Varmilo custom shop is the closest you will get for turning a Varmilo into what you want, short of desoldering.
You can order various hotswap TKLs and full-size from GMMK, Archon, Monstargear, and Everglide that can be ordered without any switches or keycaps.
