Author Topic: YMDK Case USB C Daughterboard  (Read 3774 times)
Offline holycow234234
« on: Mon, 31 May 2021, 23:04:22 »
I made a usb c daughterboard for the YMDK/Aliexpress tkl case.
I made this for myself, but I hope someone else finds it useful.
(Be gentle this is my first design)
It installs the same as the regular daughterboard, you just have to push fairly hard so the screws cut threads in the plated holes.
Github: https://github.com/holycow234234/YMDK_USB_C
BOM:
GCT USB4105 Usb type C port
2x 0805 5.1k ohm resistors
Photos:
Edit: typo
« Last Edit: Tue, 01 June 2021, 07:08:08 by holycow234234 »
Offline fpazos
Re: YMDK Case USB C Daughterboard
« Reply #1 on: Tue, 01 June 2021, 03:00:46 »
Thanks. I was very curious about this case. Which main board did you used?
Enviado desde mi Redmi Note 7 mediante Tapatalk
Offline piit79
« Reply #2 on: Tue, 01 June 2021, 06:33:28 »
Thanks! I'm probably going to use it. I bought 2 of these cases with the hope of making a cheap alu TKL. Also very interested to know what PCB you used!
« Reply #3 on: Tue, 01 June 2021, 07:16:36 »
I used the xmmx board https://geekhack.org/index.php?topic=93422.0 (read my replies towards the bottom)
Couple issues I had:
My included cable wasn't long enough so I would have had to extend it, but,
I didn't have enough clearance to connect the jst connector so I ended up just hardwiring it, you might have better luck with a right angle connector.
