Author Topic: Corsair K63 I key double tapping after 2 and a half years of use  (Read 2681 times)
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
I've seen in my past gameplay videos and my current gameplay videos that my i key as well as other keys are starting to double register. Also, the entire oem keycap set was chipped a while ago and i think it's time for me to get a new one. How do i fix?
Just my thoughts
Re: Corsair K63 I key double tapping after 2 and a half years of use
« Reply #1 on: Wed, 02 June 2021, 14:08:02 »
Is there a pattern, like all the keys being in the same row, or are they all just keys you use more often than the rest?  If there is a pattern it could be a failing controller, if heavy use it could be the switches which can be desoldered and replaced.
Offline Sintpinty
    • My Roblox Profile
« Reply #2 on: Wed, 02 June 2021, 21:01:28 »
The keys that are double tapping include the I and O keys, and sometimes the a and e keys as well. Mainly the vowel keys are doing it but constant letters can also do it. Needless to say i do not have a solder at hom and my keyboard is long past its warranty so i'm thinking im getting a replacement this summer. And you know what that means: fk the linears go clickies
« Last Edit: Thu, 03 June 2021, 21:04:13 by Sintpinty »
Just my thoughts
« Reply #3 on: Fri, 04 June 2021, 09:19:27 »
Yup, sounds like you managed the millions of clicks required to kill some switches.
Clickies, so a model M?
Offline Sintpinty
    • My Roblox Profile
« Reply #4 on: Fri, 04 June 2021, 12:12:23 »
Idk maybe a huntsman or gmmk
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #5 on: Fri, 04 June 2021, 12:19:28 »
So it's just regular wear and tear then? It seems like due to my fast typing speed keyboards fear me. I wore mine out a lot more faster than it should have.
Just my thoughts
« Reply #6 on: Fri, 04 June 2021, 12:44:40 »
Could it be dust?  You could get a can of compressed air and squirt it in each switch while it's pressed (keycap removed) and see if that helps.
