Author Topic: (IC) GMK Aquarius Base Kit  (Read 7167 times)
Offline ebomb2
« on: Wed, 02 June 2021, 13:15:50 »
Hello everyone! This is the GMK Aquarius, my first test renders for this keycap set.
Noticing the demand for these keycaps: https://kbdfans.com/products/enjoypbt-abs-doubleshot-mechanical-keyboard-keycaps-set-6
I decided to make a slightly more vibrant, (and better looking imo) version of these.
        If you want to give me feedback: https://docs.google.com/forms/d/e/1FAIpQLSddVANNeBMOXjOuP3Ktbb3JMhG4RjCH1TYs-kBKFeo3zxp8gg/viewform?usp=sf_link
Offline Alessio
    • YT Channel
Re: (IC) GMK Aquarius Base Kit
« Reply #1 on: Wed, 02 June 2021, 13:17:00 »
i approve of the name
Offline of_sam
« Reply #2 on: Wed, 02 June 2021, 13:17:16 »
So you're just trying to copy another colorway. Did you get their permission?
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline Pontus
« Reply #3 on: Wed, 02 June 2021, 13:17:38 »
Needs more work :-X
Offline MIGHTY CHICKEN
« Reply #4 on: Wed, 02 June 2021, 13:17:57 »
No
Offline Banned
« Reply #5 on: Wed, 02 June 2021, 13:21:25 »
Uhm..... You copied another set, slapped another name on it, and posted it without any further work? Having felder renders/a set that is not fleshed out at all I understand but stealing someone else's colors? Come on, dude.
Offline ebomb2
« Reply #6 on: Wed, 02 June 2021, 13:37:59 »
They are dif colors and was told they look similar to another set before I knew they existed lol. This is original I just didn't know there was something like this until this morning before I made this post.
« Reply #7 on: Wed, 02 June 2021, 14:05:09 »
So you knew it looked similar? Then don't post, your idea is basically a copy and not in the slightest ready, you basically have default dakota felder that probably took minutes to make this "base kit"
Offline Baka Bot
« Reply #8 on: Wed, 02 June 2021, 14:38:11 »
Looks like something a huge corporation would produce.
Offline ebomb2
« Reply #9 on: Wed, 02 June 2021, 15:38:17 »
Welp I hear ya folks, its a bad keycap set. back to the drawing board
Offline IOVERCALLHISTIOCYTES
« Reply #10 on: Wed, 02 June 2021, 15:46:40 »
It’s a fine keycap set. If this came fleshed out w renders, some novs, reference colors chosen, well thought out kitting, and the like, it would probably make MOQ. What was bad was your effort.
Offline ebomb2
« Reply #11 on: Wed, 02 June 2021, 15:55:02 »
yea it was my first time doing it so I really don't know how to format it and everything. Ill definatlly come back later with a much more improved set
Offline Banned
« Reply #12 on: Wed, 02 June 2021, 17:24:47 »
Please do. Check out other peoples IC's and see what they have, and use that as an example. I recommend you join the Keycap Designer Discord as well: https://discord.gg/PTBEc6zw
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #13 on: Wed, 02 June 2021, 17:43:23 »
Just look at any other IC to see that this is not how an IC is supposed to be made. Is it really this hard?
Offline MrGuccu
« Reply #14 on: Wed, 02 June 2021, 17:58:09 »
Bro at least fix the felder files
Offline trukeeb
« Reply #15 on: Wed, 02 June 2021, 22:30:41 »
As another member mentioned I would look at joining the keycap designer discord channel to assist with building out your idea
Offline ZavaZ86
« Reply #16 on: Thu, 03 June 2021, 01:23:02 »
HK gaming would like to hire you
Offline AstralYT
« Reply #17 on: Thu, 03 June 2021, 01:28:35 »
Good set, but I wouldn't buy it if as a GMK set. Looks like some infinikey or a geekark set.
Sent from my Redmi Note 7 Pro using Tapatalk
Offline Shiba1337
« Reply #18 on: Thu, 03 June 2021, 01:52:56 »
Low effort, copied colorway
Sent from my Samsung Smart Refrigerator using tapatalk
Offline ebomb2
« Reply #19 on: Thu, 03 June 2021, 02:07:10 »
Yea this is scrapped way better one is here https://geekhack.org/index.php?topic=113175.msg3055362#msg3055362
