Author Topic: Is there a good way of lubing tactile switches?  (Read 4580 times)
Offline BlueberryIsHere
  • Formerly KaptainKitsune
  • Just a normal guy
« on: Fri, 04 June 2021, 07:48:59 »
Just want to make sure that I'm not going to ruin my switches. Thanks in advance.
I was told to put something here.
So I did
Offline Ranger_Trivette
Re: Is there a good way of lubing tactile switches?
« Reply #1 on: Fri, 04 June 2021, 08:13:39 »
disassebly the swtich.
lube the spring and all the plastic parts that create friction while moving.
use a thin brush and a proper lobe :)
on youtube you can find thousands of videos ;)
Offline Volny
« Reply #2 on: Fri, 04 June 2021, 08:16:27 »
Yeah, look on YouTube. Eg. JUJU or Taeha's guides. The main thing is to avoid the metal leaf and the little knub on the stem that hits it.
  • Just a normal guy
« Reply #3 on: Fri, 04 June 2021, 08:25:35 »
Alright, thanks bro. Just wanted to confirm.
So I did
Offline katotaka
« Reply #4 on: Sat, 05 June 2021, 10:28:07 »
IMO avoid the part that creates the bump
Offline Sup
« Reply #5 on: Sun, 06 June 2021, 15:21:08 »
If you want to decrease tactility go ahead but, i would recommend just lubing the sides of the switch and the housing. Don't lube the switch leaf and the legs though.
current
Coming soon
Offline chadrezzar
« Reply #6 on: Tue, 08 June 2021, 17:03:45 »
It just depends on your preference really. You can lube the legs aswell but it decreases tactility. Personally I lube the leaf&legs because I abhor ping of any kind(leaf ping, spring ping, you name it :) ) and I usually prefer my tactility on the milder side.
If you're not sure just grab a couple switches lube the legs&leafs and do a couple where you don't touch the legs&leaf. If you only have exactly the amount of switches needed for your board (and you end up disliking the milder tactility) you can either clean it or throw the "ruined" switches on some keys where you probably won't notice it(ie F6/F7/F8 or something).
« Last Edit: Tue, 08 June 2021, 17:08:52 by chadrezzar »
