Author Topic: [IC] Magnetic Corne Case. Soundtest/Comparison and google survey  (Read 5169 times)
Offline Runningtarrens
HI all.
My Printer has a bit of down time atm. So i thought i might make a small GB for the Magnetic Corne Case.
Its a 3D Printed Case, that uses magnets instead of screws and standoffs. So you need less hardware to Build it and can open it without any tools
269901-0
269903-1
Scope of the GB would be the Case, magnetic tenting legs and Oled cover.
270438-2
Color options:
For the Case and the tenting legs: White, Matt Black(a bit less glossy), transparent, dark blue, grey, Neon Orange and glow in the dark.
Materiel will be PLA.
269907-4
269909-5
269911-6
269913-7
269915-8
269917-9
some examples of the colors in finshed prints.
269919-10
For the Oled cover there is clear, smokey, frosted violet and frosted blue-ish. the last both distort the light from the oled, you wont be able to read whats on the oled.
The oled cover is customizable, you can get it engraved with the corn logo, that logo can also be colored and the cover can have a cut out so you can still read it when using the frosted colors.
All covers are made out of acryl and are 3mm thick, exept for the clear ones they are only 2mm.
examples:
269923-12
269925-13
269927-14
269929-15
some pics of the tilting legs:
269933-17
because its all seperated you could mix all the colors. one half black the other white or 4 different colors for the different parts.
color match the tenting legs or make them transparent so they glow in the color of the underglow LEDs.
the color for the engraving of the oled cover can also be chosen, like black, white, violet, blue etc.
price would be 75 Euro
amount: about 10ish
production time would be 1 or 2 month.
i would like some feedback. Is that something you want?
Link to the servey
https://forms.gle/dWDLi4J72pGCo9r88
Soundtest and Comparison
Soundtest
Sound comparison with the IMK Case
« Last Edit: Fri, 11 June 2021, 13:24:16 by Runningtarrens »
Offline finalarcadia
Re: [IC] Magnetic Corn Case
« Reply #1 on: Sat, 05 June 2021, 12:24:30 »
How do you magnetize corn and what is the benefit
Offline yotasan
    • ARCANE - PHOTOGRAPHY ARCHIVE
« Reply #2 on: Sat, 05 June 2021, 12:33:14 »
Looks cool, I would buy it.
Offline Alejo1707
  • Gimme some more caps!
« Reply #3 on: Sat, 05 June 2021, 12:33:55 »
Interested!
Sent from my GM1917 using Tapatalk
« Reply #4 on: Sat, 05 June 2021, 13:27:46 »
there are 20 magnets embedded into the case.  4 in each half to hold the halfs together and  +2 in each bottom for the magnetic tenting legs.
you dont need screws and standoffs to use this case. ist a bit cleaner because you dont see screws from the top or bottom(except the 2 for the oled cover).
And you dont need to unscrew ,if you need access to the pcb. with the magnetic case you can just open it in seconds without the need for tools, which was the original reason why i made this case.
Also it is a better print because ist doesnt need support while printing and you can mix and match the parts after your liking.
i attached some more pics/gifs
269972-1
here you can see the magnets in the case:
« Last Edit: Sat, 05 June 2021, 14:38:16 by Runningtarrens »
Offline afrokobe
« Reply #5 on: Sat, 05 June 2021, 13:39:59 »
i dont see any corn
Offline treeleaf64
    • treeleaf64
« Reply #6 on: Sat, 05 June 2021, 14:15:59 »
So it is like an integrated plate with the top case, and that will fit into the bottom case with the help of the magnets. Cool design. i will  look into it more
Everyone must pay the cat tax
Re: [IC] Magnetic Corne Case. Soundtest/Comparison and google survey
« Reply #7 on: Fri, 11 June 2021, 13:28:20 »
HI all.
Color options:
examples:
amount: about 10ish
Link to the servey
Soundtest
i added a pic of the kit. a soundtest and a  sound comparison with the IMK case.
also i added a survey so please fill that out if you want help me  :thumb:
