Author Topic: Alpaca V2 has inconsistent stem hole size?  (Read 2182 times)
Offline jooobe
« on: Wed, 09 June 2021, 08:20:28 »
I'm wondering if anyone has run into this, I'm stem swapping to UHMWPE stems. The same stem can fit into one bottom housing but somehow not some other ones. If I look closely some stem hole has thicker walls than other ones
Offline Leopard223
Re: Alpaca V2 has inconsistent stem hole size?
« Reply #1 on: Sat, 12 June 2021, 10:53:36 »
I can see that happening, tolerance is probably meant for the Alpaca stem.
Just like when making Holy Bobas, some switches will have the stem stuck due to different sizes.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #2 on: Sat, 12 June 2021, 11:24:57 »
The culprit is more likely the UHMWPE stems than the Alpacas. UHMPE stems are notorious for having noticeable variance from one unit to another.
