Author Topic: Where to buy good keycaps from  (Read 4047 times)
Offline Codename_A
« on: Thu, 10 June 2021, 00:50:35 »
Ok so I have a GMMK Pro TKL ansi and I have mx blacks. I am confused on where to buy high quality keycaps. My theme is either red and black, blue and white, or green and white. Does anyone know where to buy good switches or a good set? Thanks!
Offline Suds
Re: Where to buy good keycaps from
« Reply #1 on: Sat, 12 June 2021, 19:58:24 »
There are lots of sources for both of those. It depends what switches you want, what kind of keycap profile(s) you're after, etc. Just a few options: for switches try NovelKeys. For keycaps I like YMDKey.com, but there are also a lot of options on Aliexpress or Bangood.
