Author Topic: Best lube for Zilents v2?  (Read 3227 times)
Offline asgeirtj
« on: Thu, 10 June 2021, 07:39:29 »
Can anyone recommend me a good lube to buy in Europe for these switches? Also, would you guys lube everything except the legs? Am looking for something which would retain the tactility the most. Also does anyone recommend filming the zilents v2?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline Error213
Re: Best lube for Zilents v2?
« Reply #1 on: Thu, 10 June 2021, 09:33:06 »
I mean 3203/ 203g0 is what everyone recommends for tactiles, imo you can use 3204 also just not 205g0
Offline phinix
« Reply #2 on: Thu, 10 June 2021, 15:48:52 »
Why 205g0 is bad for tactiles?
I'm about to lube Zealios v2 78g with mixture of 205+105 (60/40).
Is it bad idea?
Offline keebees
« Reply #3 on: Thu, 17 June 2021, 22:44:58 »
Is it bad idea?
Hi, I've lubed some Durock T1s with 205g0 for uhhhhhh science, definitely not because I had no idea what I was doing, nope.
Anyway, it makes the switches somewhat gummy feeling. Like there is some double sided tape inside the switch fighting against you as you try to break past the tactile point. Also it is very, very difficult to remove the Krytox afterwards. I didn't like it.
