Author Topic: Glorious GMMK Pro review (5,700 words after 2 months of use)  (Read 7837 times)
Offline jasontsay
    • Material Journal
« on: Fri, 11 June 2021, 18:59:00 »
I’ve been sitting on this review for a while now, but here is my in-depth take (a little over 5,700 words) on the GMMK Pro after 2 months of use. I purchased the keyboard with my own money in the first pre-order batch.
Hope this is helpful for someone out there, and feel free to let me know if you have any questions or feedback!
Review Link - https://materialjournal.com/blog/glorious-gmmk-pro-review
Publishing content on deliberate materialism at Material Journal. Can also be found on Instagram @jasontsay.
Offline kizuna
Re: Glorious GMMK Pro review (5,700 words after 2 months of use)
« Reply #1 on: Sun, 13 June 2021, 14:04:38 »
Thank you for the in depth review!
Offline jasontsay
    • Material Journal
« Reply #2 on: Tue, 15 June 2021, 05:15:18 »
Thank you for taking the time to check it out!
Offline kizuna
« Reply #3 on: Wed, 16 June 2021, 10:35:00 »
You're welcome!
