Author Topic: Cheap Alps-compatible numeric keypads readily available - 17a 18a 19a 20a keypad  (Read 2060 times)
Offline linuxleah
For various projects, I was looking for cheap Alps-compatible numeric keypads (as in, I didn't care if they came with the world's worst scratchy Alps clones; I was going to rip off the keyswitches and keycaps and use my own donor switches and caps), and found a source, in case anyone is interested.
These are the same ones mentioned at https://www.reddit.com/r/MechanicalKeyboards/comments/6x3gkn/help_anyone_know_where_i_can_buy_a_stb17a_a/
I got mine from https://www.dhgate.com/product/stb-17a-a-mechanical-numeric-keypad-best/396358335.html?d1_page_num=1&dspm=pcen.sp.list.2.a1IIa5dl9ZwGOO5IW7m1&resource_id=396358335&scm_id=search.LIST...NDBADF|0|0.#s1-1-1;searl|0702641829:2 but they seem to have cranked up their prices. However, searching dhgate for "STB-17a" reveals other sellers who are cheaper.
Should make a good donor case, plate, and board for building Alps numeric keypads, macro pads, or key testers (Chyrosran22 on youtube uses one as the base for a tester; see attached picture showing his one with many many different switches in there... he seems to have cut additional holes in the plate, as mine has a double-wide "0", double-tall "+", and double-tall "Enter" keys I suspect he uses the "STB-20a" model as per https://www.dhgate.com/product/stb-20a-a-mechanical-numeric-keypad-best/508671138.html?d1_page_num=1&dspm=pcen.sp.list.1.xw4EJiTGP6TLuqTuG7mT&resource_id=508671138&scm_id=search.LIST...NDBADF|0|0.#s1-0-1;searl|0747351828:1) :)
There are also apparently "stb-18a", "stb-19a", and "stb-20a" keypads with (you guessed it) 18, 19, and 20 keys!
Teardown of one of these "stb-17a"s that I found on youtube; the person in the video does a pretty thorough dissection.
« Last Edit: Mon, 14 June 2021, 23:56:34 by linuxleah »
Offline MIGHTY CHICKEN
Interesting, always seen them on china sets although was skeptic about them, great post!
Offline linuxleah
No worries! BTW, here's a teardown video I found on youtube.
