Author Topic: First build ever... Not working. Please help  (Read 3901 times)
Offline Dagrylls
« on: Tue, 15 June 2021, 01:04:05 »
So I just finished soldering on some cherry browns I harvested from an old broken keyboard onto a little case/PCB my coworker gave me. However, when I plug it in, I cannot type. It registers on my PC, I get the notice that a new keyboard is being set up from windows. But pressing keys does not register any input. Any ideas what I could do to fix this?
Re: First build ever... Not working. Please help
« Reply #1 on: Tue, 15 June 2021, 03:26:36 »
Soldering looks OK, but even if a couple of joints are bad or pads damaged from the desoldering (there are usually a couple) the rest should work.
What PCB is it?
Offline Dagrylls
