Author Topic: dz60rgb-ansi v2 hotswap - using VIA but can't get macros to run.  (Read 4420 times)
Offline arydi
I'm having trouble flashing macros on the dz60rgb-ANSI v2 hot swap pcb.
I am using VIA. I edited the keymap in VIA without a problem, but I had problems with macros.  VIA shows the macros have been written and assigned correctly, but when I actually try to use the keyboard, the macros don't run.
I've done this for other VIA-supported pcbs and never had this issue before.
Any ideas?
