Author Topic: [GB] - CU1 (GB is Live!)  (Read 3541 times)
Offline CAPS UNLOCKED
    • capsunlocked
« on: Mon, 21 June 2021, 13:08:46 »
Store Link: https://caps-unlocked.com/group-buy-cu1-round-1/
Price: $41.75
Start Date: 21 - 06 - 2021
End Date: 19 - 07 - 2021
Expected Fulfilment Date: Q4 2021
The CU1 is a single rotary encoder that is reprogrammable via QMK. The rotary encoder is the same one that is being used on the CU7, and does not feature detents and turns infinitely with no defined stops.
The outer casing and dial are made entirely of Aluminium; the dial design is the same dial on the CU7. Finally there are three silicone feet that attach to the bottom to prevent the Aluminium base from touching any surfaces.
The PCB supports a single USB-C port, the kit is not wireless.
Additional Dials
If you would like to purchase additional dial please click here: https://caps-unlocked.com/group-buy-dial/
What's in the box?
- Aluminium Dial
- Aluminium Case
- PCB (all components are pre-soldered)
- 3 x Rubber Feet
- 1 x 1.3mm Allen Key
- Assortment of screws.
Images:
270985-0
270987-1
« Last Edit: Tue, 22 June 2021, 14:54:20 by HoffmanMyster »
Re: [GB] - CU1 (GB is Live!)
« Reply #1 on: Tue, 22 June 2021, 14:55:10 »
Approved :thumb: (also slightly edited to include price and timing information)
