Author Topic: Drilling holes in a 65% plate  (Read 4830 times)
Offline gudetamae
« on: Wed, 23 June 2021, 12:37:55 »
Hey everyone,
I just bought my first mechanical keyboard (RK G68) and I've been meaning to change the plate to a brass plate. The plate that came with my keyboard is non-standard and the screw holes don't align with the ones sold on KBDFans for the Tofu65. Would it be possible to drill holes in the 65% plate from KDBFans to solve this issue?
Current plate on keyboard (picture taken from a reddit user): https://imgur.com/a/yfSIQ5g
Plate on KBDFans for Tofu65: https://kbdfans.com/collections/65-layout-plate/products/65-brass-plate
Sorry if this is a dumb question but any help would be appreciated!
Offline nevin
Re: Drilling holes in a 65% plate
« Reply #1 on: Wed, 23 June 2021, 12:45:47 »
are the screw holes the only thing that's off?
....you're trying to use a plate for a tofu case for the case of a RK G68
... does the plate fit otherwise?
... everything line up as it should except for the screw holes?
... are you using a different pcb as well or just changing plate material? (you probably won't see a big difference going from say an aluminum plate (which i'm guessing is in the RK G68) to the tofu brass plate.
if everything checks out, put the old plate on top of the new plate and mark & drill the new holes.
