Author Topic: Filco Majestouch 2 Chattering?  (Read 1395 times)
Offline F eq ma
« on: Wed, 23 June 2021, 22:51:51 »
I seem to be experiencing key chatter on my Filco Majestouch 2 full size board.  Since the chatter is happening on various keys across rows and columns, I am worried the board may be failing and not a specific key.   Any suggestions to troubleshoot?
The keyboard is about three years old, used daily (9 hours per day or so).  Cleaned regularly.   Keycaps replaced about three months ago with stabs lubed lightly about a month ago.
I do have it hooked up to a usb on the monitor, instead of directly to the laptop.   I have yet to see if a direct usb connection has the same issue.  Can key chatter be associated to usb hubs, essentially what the monitor is playing?
