Author Topic: tecware phanntom elite mod to usb c detach  (Read 4893 times)
Offline devilcry
« on: Sat, 26 June 2021, 22:50:26 »
I have tecware phanmtom elite 104 and i use 5 pin USB on the PCB 5V,D+,D-,Ground, and SG. So, what is SG do ? https://i.ibb.co/Yk1dHLh/IMG-20210626-200753.jpg
for usb c breakout, which board i should buy ? standar usb c with only 4 pin need to solder ? https://www.aliexpress.com/item/1005002795893679.html
11-more pin need to solder ? https://www.aliexpress.com/item/1005002796478202.html
or maybe breakout like sparkfun USB C Bob : https://www.sparkfun.com/products/15100
Phantom Elite 104 Gateron Red.
Offline piit79
Re: tecware phanntom elite mod to usb c detach
« Reply #1 on: Sun, 27 June 2021, 03:10:02 »
I think SG could be "shield ground".
For USB 2.0 device to work with USB Type C, you just need to connect the usual 4 pins (VCC, GND, D+, D-) and additionally connect CC1 and CC2 to ground each via its own 5.1k resistor (to set the correct USB device mode). You can ignore all the other pins.
Just watch out - because USB-C is reversible, all pins exist in pairs: 1 in the top row and one in the bottom row. So D+ is actually 2 pins - DP1 and DP2, that need to be connected together. Same with D- (DN1, DN2) VCC and GND (there are actually 4 pins for each).
Hope that helps :)
Offline devilcry
« Reply #2 on: Sun, 27 June 2021, 06:02:57 »
Hope that helps :)
thanks for your information and help. Should i care about "shield ground" or just leave it ( not connect to anything ) ?
and, it's better to buy usb c breakout with only 4 pin like this (https://www.aliexpress.com/item/1005002795893679.html) ? because it is simple dan safe ?
sorry my english.
« Reply #3 on: Sun, 27 June 2021, 06:14:08 »
The 4 pin only connects D- to one pin so it will only work with the cable one way up.
