Author Topic: Magnet GB post need approval by a moderator  (Read 7592 times)
Offline SFT StarDust
« on: Fri, 02 July 2021, 00:32:40 »
Hi dear Moderators:
My GB post is upload for over week ,and it's still waiting approval by a moderator.
I really need your help .
the link: https://geekhack.org/index.php?topic=113396.msg3059553#msg3059553
thanks a million.
Lee
Re: Magnet GB post need approval by a moderator
« Reply #1 on: Fri, 02 July 2021, 02:31:08 »
You can always click the "Report to moderator" link to the right of the screen (or your GB post) and politely bring it to the moderators' attention.
Offline yui
« Reply #2 on: Fri, 02 July 2021, 03:48:21 »
and just in case as you are quite new maybe check if you follow the rules correctly:
https://geekhack.org/index.php?topic=88717.0
