Author Topic: IBM ThinkPad external keyboard with UltraNav  (Read 2523 times)
Offline netwebber
Keyboards: IBM M15 adjustable ergonomic | Northgate Omnikey Evolution w/ Touchpad | IBM Model M 1391401 | TG3 BLT 5RBUVS tenkeyless | MS Natural Keyboard Pro | MS Natural Keyboard Original (Black) | IBM UltraNav Travel Slim Keyboard | Chicony ThinkPad T60 keyboard in Lenovo ThinkPad T400 | IBM ThinkPad T42p | MS Arc Wireless | Logitech K350 Wireless
Pointing Devices: Logitech G500 | Logitech Anywhere Mouse MX | IBM ScrollPoint Optical | Razer Boomslang | On laptops: Trackpoint for pointing, touchpad for scrolling--The True Way
Other: Belkin/Razer Speedpad n52te | Adesso Mechanical Numpad (Cherry Blues) | Wacom Intuos2
Game Controllers: MS Sidewinder Force Feedback Pro | Gravis Exterminator
Offline EverythingIBM
« Reply #1 on: Thu, 26 August 2010, 14:54:28 »
They're just standard switch domes, OK, but short keys really bother me. I think all keycaps should be nice and tall.
Definitely not worth $70 to be used at a home computer, you could get a model M13 for that price. Buckling springs & a trackpoint.
If they were $20, I'd buy one.
Offline shem
« Reply #2 on: Thu, 26 August 2010, 15:21:00 »
I have one with numpad and touchpad that I use at home, and another without numpad ("travel" model) that I take with me when I visit data centers to work on rack-mounted servers.
I chose it for home use because I have a quite cramped keyboard tray that can only just accommodate a small keyboard and a trackball. I don't type very much at home and I've been quite satisfied with the Ultranav. I've grown used to using mouse buttons on the keyboard and using the trackball mostly for moving the pointer. That said, the typing feel of this keyboard is nothing special and I think I'll replace it at some point with something having mechanical switches.
The travel model on the other hand is ideal for travel use. It's compact and has a pointing device if I happen to use a windowing system. The standard USB cable can be coiled neatly under the keyboard but it is very short and I always carry a USB extender. It comes with a carrying case.
HHKB2 pro, IBM Ultranav(travel & normal), AT102W, VT220, IBM model M Space Saver, IBM model F AT, Matias Mini Tactile Pro, JD45
