Author Topic: [IC] Custom braided USB Cables | Botanical  (Read 3754 times)
Offline calmfries
  • Formerly CalvinXC
  • Broke af
« on: Sat, 03 July 2021, 12:19:23 »
Hi all, here I am running IC for custom handcrafted braided USB cables as an artisan service should there be enough interest and demand for it.
I aim to provide a premium quality product that complements the amazing keyboards and keysets that are growing in this community.
In the first attempt, I will be crafting this cable around the Botanical theme, inspired by the beautiful GMK Botanical keycaps set.
This means that the cable will be color-matched to the exact colors used in the set.
271696-0
Credit: Render from Botanical GB thread
271753-1
I have received a green light from Hazzy, the designer of the Botanical set to use the exact color combination on this custom cable.
However, as a disclaimer, it shall be noted that this does not signify any affiliation with Hazzy or the official GMK Botanical GB. This is solely an independent project by me.
Now onto the structure of the cable, it is braided with multiple strands of wires into one single cable.
Shown here is an example of what I've made few years ago (iykyk ;) ). Aviator connector will be added in prototype and final product
271751-2
This is my second take on custom braided USB cable, trying to offer something that is different to the market. Aside from modernising the cable with modern features i.e. detachable connectors,
I am also aiming to lift up the quality quite a few notches higher than where I was few years ago.
The format of sale will be likely be pre-order and FCFS only, there will likely be a cap on quantity of orders as this product is handcrafted and requires significant amount of man-hours to complete just a single cable, compared to more common cable construction.
Ultimately, quality prevails over quantity.
This will definitely not be a quick IC as there are lots of work that goes into color matching as close as possible with the wire manufacturer and possibly many hiccups in prototyping before I start taking orders. The prototyping process should begin soon after I gather enough interest to start the project.
As for price, you can expect it around the range of other premium cable offerings, varies with length and options.
Specifications:-
Length: 1ft - 6ft
Connection: MiniUSB, MicroUSB and Type C
Detachable connector: 5pin aviator
Starting date: TBA
Price: TBA
Est. Shipping time: ~2 Months after Pre-order
Shipping cost: TBA (This will need some work to keep it reasonable for International buyers)
« Last Edit: Sun, 04 July 2021, 12:19:39 by calmfries »
B87 | TGR 910 CE
Offline Baka Bot
Re: [IC] Custom braided USB Cables | Botanical
« Reply #1 on: Sat, 03 July 2021, 20:31:45 »
why is it that when I click on the image it doesn't expand?
Offline calmfries
  • Formerly CalvinXC
  • Broke af
« Reply #2 on: Sun, 04 July 2021, 12:21:33 »
Rectified. A higher resolution image is added.
Also, IC form added. Do consider filling up if you're interested.  :thumb:
B87 | TGR 910 CE
Offline EnlargedCrouton
« Reply #3 on: Sun, 04 July 2021, 18:56:08 »
really cool, I personally wouldn't buy in the botanical theme because I don't have any green sets, but if you have other colors in the future I would be interested glwic
