Author Topic: IBM Model M equivalent?  (Read 2941 times)
Offline fragment
« on: Thu, 26 August 2010, 15:56:36 »
Hi,
Would a 'DAS Model S Professional Keyboard' be an equivalent or suitable replacement for an IBM Model M?
Thanks.
fragment
Offline keyboardlover
« Reply #1 on: Fri, 27 August 2010, 07:44:57 »
Quote from: fragment;217006
Hi,
Thanks.
fragment
Depends what you want to replace it with. If you want to replace it with nearly the identical thing, go with ripster's advice. The Model S (Silent) has brown cherries, which are mechanical, tactile, non-clicky switches. Because they're non-clicky, they don't make a lot of noise. They feel a lot different from bucking springs (the switches that the Model M uses).
Offline didjamatic
« Reply #2 on: Fri, 27 August 2010, 07:57:56 »
Fragment, welcome to geekhack!
Can you tell us more about what you want?  Model M's are all over ebay, so if it's a M you seek, check there.  If you're wanting something similar or different, help us understand what you are looking for.
Offline fragment
« Reply #3 on: Wed, 01 September 2010, 12:24:14 »
Thanks! I actually ended up purchasing the Das Keyboard Model S Professional Silent. Loving it! Trying to do some research to see if they have any custom keycaps.
« Reply #4 on: Wed, 01 September 2010, 14:37:17 »
Quote from: fragment;218867
Nice choice...I like cherry browns. Glad you found a good replacement.
