Author Topic: [GB] GMK HANOK 한옥 - In Production!  (Read 18956 times)
Offline JKKEEBS
« on: Wed, 07 July 2021, 15:57:46 »
Set is now in production!
Vendors:
Estimated shipping date: Q3 of 2022.
_____________________________________________________________________________________________________________
ALL vendors and I have decided to donate 30% of all PROFITS to the organization "Hate Is A Virus" and other non profit orgs.
 As you may know there have been many hate crimes towards Asians all over the world due to racism and Covid-19. With the help of Hanok's vendors and this platform I hope to spread awareness using the set.
Entry Steps:
1. Follow me on Instagram @JKKEEBS
2. Repost my most recent post on your story and tag me.
3. Join my Discord
*FINAL*
Base
Gray Mods
Novelty
Spacebar
N9 Deskmat and L9 Deskmat
Iron 180
M60
F1-8X
Kibou's 'Harbour'
Vanquish 65
*note* Colors are not 100% accurate on renders. I found that higher resolution or color accurate monitors show darker browns and grays that show a drastically different feel of the set.
^^^^ CLICK ^^^^
Colors
Beige: L9
Gray: N9
Brown: Ral 8028
Keycap specs
Profile: Cherry
Sculpt: 1 - 1 - 2 - 3 - 4 - 4
Legends: Doubleshot
Modifier Style: Icon+Text
Material: ABS Plastic
Thank you to Fredington! Designed deskmat and novelties! Thank you for helping me with everything and anything I needed help with. This set would not have been possible without Fredington thanks!
Thank you to KingK22 for the amazing renders!
Thank you to Manzel for the amazing renders on the Iron 180!
Thank you to everyone that supported the set!
Thank you to Taeha Types for using the deskmat on stream.
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=110801.0][img]https://i.imgur.com/tiYQ6pN.png[/img][/url]
« Last Edit: Sat, 25 November 2023, 18:13:39 by JKKEEBS »
Re: [GB] GMK HANOK 한옥 - July 26th to August 23rd
« Reply #1 on: Mon, 26 July 2021, 16:31:32 »
Approved :thumb:
Offline JKKEEBS
« Reply #2 on: Fri, 30 July 2021, 14:33:09 »
Taeha Types will be giving away a hanok bundle on his subathon!
Offline //gainsborough
  • MATRIXの日常
« Reply #3 on: Sun, 01 August 2021, 20:48:51 »
out of sheer curiosity, is anyone planning on using the monokei artisan for their entire f-row?
Offline JKKEEBS
« Reply #4 on: Sun, 01 August 2021, 20:55:00 »
LOL our discord had the same idea.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #5 on: Mon, 02 August 2021, 03:35:58 »
Offline busytimmy
« Reply #6 on: Mon, 02 August 2021, 19:09:51 »
ne info avail on the Casper Keys artisan?
Offline JKKEEBS
« Reply #7 on: Tue, 03 August 2021, 21:14:38 »
What info are you referring to?
Offline dvorcol
« Reply #8 on: Tue, 10 August 2021, 14:44:49 »
Offline dvorcol
« Reply #9 on: Wed, 18 August 2021, 18:36:01 »
« Last Edit: Sun, 22 August 2021, 18:18:05 by dvorcol »
Offline JKKEEBS
« Reply #10 on: Sun, 22 August 2021, 20:16:55 »
Thank you!
ONlLY FEW HOURS LEFT ON HANOK DON"T MISS IT!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #11 on: Sun, 22 August 2021, 22:56:47 »
Thank you!
So does it end tonight? Or tomorrow? GB end date says 8/23
Offline JKKEEBS
« Reply #12 on: Tue, 24 August 2021, 22:02:16 »
Prototypist is open till tomorrow, if you missed the set buy from Prototypist!
Better than gambling but also cheaper instead  buying extras at a higher price.
Offline dvorcol
« Reply #13 on: Mon, 06 September 2021, 21:44:40 »
« Last Edit: Tue, 07 September 2021, 02:33:51 by dvorcol »
Offline dvorcol
« Reply #14 on: Tue, 07 September 2021, 02:33:40 »
<-- without extras
Offline JKKEEBS
« Reply #15 on: Sun, 07 November 2021, 00:08:15 »
HI!
Check your favorite typing site Monkey Type
for HANOK theme!👀👀
Offline JKKEEBS
« Reply #16 on: Fri, 25 February 2022, 16:04:37 »
Hi again! I received sample RAL 8028 sample caps, here are a few pictures.
Offline JKKEEBS
Re: [GB] GMK HANOK 한옥 - In Production!
« Reply #17 on: Sun, 16 April 2023, 18:41:49 »
Received an update this month confirming the production of the set!
