Author Topic: Omen Hp Sequencer Keycap replacement  (Read 7947 times)
Offline donny
« on: Thu, 08 July 2021, 06:16:31 »
Hello, can you pls help me, I have hp sequencer with a missing key the pg dn (see image), how can I replace it? couldn't find a replacemant anywhere, any key will do, doesn't have to be an original, even a blank one, something from ebay that will fit.
Here's the neighbour key END it says R3 inside:
« Last Edit: Thu, 08 July 2021, 06:30:14 by donny »
Offline k4jtek
Re: Omen Hp Sequencer Keycap replacement
« Reply #1 on: Thu, 08 July 2021, 06:43:19 »
I'm new here, so I think it's time to say it - Hello everyone!  ;)
You'll proper keycap here or on aliexpress. Remember it's OEM profile, not cherry.
« Last Edit: Thu, 08 July 2021, 06:49:12 by k4jtek »
Offline donny
« Reply #2 on: Thu, 08 July 2021, 06:48:05 »
You'll proper keycap here: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=r3+oem+keycap&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=r3+oem+keycap, or on aliexpress: https://pl.aliexpress.com/wholesale?catId=0&initiative_id=SB_20210708032955&SearchText=r3+oem+keycap.
Me too, hello, so any r3 keycap will do? what is the oem?
Offline k4jtek
« Reply #3 on: Thu, 08 July 2021, 06:54:12 »
Any R3 OEM profile keycap. Cherry is also a keycap profile but it's different, so it should fit but would look weird.
Offline donny
« Reply #4 on: Thu, 08 July 2021, 06:59:17 »
How do you know its oem?  :-[
Offline k4jtek
« Reply #5 on: Thu, 08 July 2021, 07:57:20 »
It should be specified in product description. If not, check this image for reference.
« Last Edit: Thu, 08 July 2021, 08:26:46 by k4jtek »
Offline donny
« Reply #6 on: Thu, 08 July 2021, 08:28:57 »
Thank you, I have another question, but I don't know if it's okay to ask it here, or open a new topic, there are three buttons that do not work the CAPS, TAB, and HOME buttons, Do you have any idea how to fix them diy, should I try and take the switches off
« Last Edit: Thu, 08 July 2021, 08:33:28 by donny »
Offline k4jtek
« Reply #7 on: Thu, 08 July 2021, 08:58:03 »
I think you should open a new topic, but if you don't want to take keyboard apart you can remap these keys with SharpKeys or similar software.
