Author Topic: TSANGAN Shine Through PBT - Do They Exist?  (Read 6621 times)
Offline TW3NTY2
« on: Thu, 08 July 2021, 10:28:12 »
Like the title says, I am looking for shine though PBT's for a custom TSANGAN layout (pictured below).
Does anyone know of any that exist or where I might be able to have them made?
Offline MIGHTY CHICKEN
Re: TSANGAN Shine Through PBT - Do They Exist?
« Reply #1 on: Thu, 08 July 2021, 10:30:51 »
That's a tough one, haven't seen any shine throughs with 7u
Offline TW3NTY2
« Reply #2 on: Thu, 08 July 2021, 11:16:00 »
The 7U and the 1.5U backspace have been the hard ones for me.  I can pretty much find everything else.
The other options would be going ABS, but still have not seen anything shine through there.  Or, I could do PBT dye-subs and just have an under glow from the keycaps.  Not really a fan of either of them though.
Offline k4jtek
« Reply #3 on: Thu, 08 July 2021, 15:17:17 »
Spacebar isn't shine trough anyway, so you can buy it elsewhere.
« Reply #4 on: Thu, 08 July 2021, 16:08:03 »
for the spacebar, you can probably just use a blank 7u bar, for backspace, its not common enough for any shinethrough to be really made so you would likely just use a normal pbt/abs or deal with wrong legends with a normal 1.5u pipe
Offline TW3NTY2
« Reply #5 on: Thu, 08 July 2021, 17:00:11 »
My OCD would drive me mad if they were not all part of a set.  I might just to go with some dye-sub pbt caps that I can order different variants of.
I was looking at a set earlier.  Would be a shame to not have the RGB shine through, but it might look cool with some key cap underglow.
Offline TW3NTY2
« Reply #6 on: Fri, 09 July 2021, 23:49:46 »
It will be a bit more expensive, but I think I am going to go with "Ice Caps" until I can locate this unicorn of a keycap setup.
