Author Topic: [IC] Sirius LinkPad ---Bluetooth5.0, RGB(GB very soon!)  (Read 6273 times)
Offline RivieraS
  • Yutop
Hi everyone,
I am Yutop. Today I brought my friend’s Sirius, the author of Uni660, Unigo, MeowTool X1, new works to meet everyone —— Sirius LinkPad
Introduce:
Sirius LinkPad, a pad with Bluetooth5.0, hotswaps , RGB LEDs. When used as an artisan keycaps storage box, it has a built-in lithium battery for LED power supply, so can display artisan keycaps that need backlighting.
Sirius LinkPad is cooperating with LNE Lab , as the first product of the new Bluetooth 5.0 solution.
The exterior design draws on the commonly used Casio calculator, uses the double-sided sliding cover design, and through the angled chute, realizes the switch between the use mode of inserting the square storage mode on the front side and the 6° inclination angle on the back side.
The Sirius LinkPad body is top mounted, made of anodized aluminum, and the transparent upper cover is made of plastic. The space between the body and the upper cover can accommodate up to the SA profile keycaps.
PCB and Plate:
has two layouts: all 1U and standard PAD.
The PCB has Kaihua hotswap, RGB Leds and built-in lithium battery.The plate is FR4 , built-in antenna to enhance the wireless signal strength.
There is a customized software to flash firmware and upgrade, support mac and windows.
Download software:https://github.com/ln-org/lne_link
Info:
  • Case has an angle of 6 degrees for the aluminum bottom
  • Hotswap, supports MX switches
  • Layout: all 1u and standard pad
  • Color:Black,Gray, Haze Blue,Dark Green,Wine Red,Rose Gold
  • Support Bluetooth5.0
  • Full RGB SMD LED
  • Switches and stabilizers are not included
One kit includes:
  • Aluminum case top and bottom x1;
  • transparent plastic cover x1;
  • Hotswap PCB x1;
  • Fr4 Plate w/antenna x1;
  • lithium battery x1;
  • foot sticker and other accessories
Price:
Update soon
GB Plan:
Update soon
Shipping:
Shipping will be from China
Shipping cost will depend on your location.
Each set weighs about 2.5kg with packaging.
Sample photos:
« Last Edit: Tue, 20 July 2021, 20:37:53 by RivieraS »
Offline Slayer77
I am very confused.
Sent from my GM1911 using Tapatalk
Offline Friendship
Re: [IC] Sirius LinkPad ---Bluetooth5.0, RGB(GB very soon!)
« Reply #2 on: Tue, 20 July 2021, 13:59:37 »
I am interested sort of. Will the clear cover require tooling of any kind? is there an approximate battery life?
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline linyaofred
« Reply #3 on: Tue, 20 July 2021, 14:18:26 »
here are some more pics
272737-0
272749-1
« Last Edit: Tue, 20 July 2021, 14:27:58 by linyaofred »
Offline Neely_12
« Reply #4 on: Tue, 20 July 2021, 14:22:15 »
Pretty expensive but seems pretty cool. Will there be an option to buy it without the battery?
Offline growler
« Reply #5 on: Tue, 20 July 2021, 15:52:18 »
214 is too much IMO. 150 tops.
Sent from my SM-G980F using Tapatalk
Don't just stare at it ...
Offline RivieraS
  • Yutop
« Reply #6 on: Mon, 26 July 2021, 20:39:14 »
Hi, we found that there is a problem with the transportation of the battery, GB may be without the battery
Offline RivieraS
  • Yutop
« Reply #7 on: Mon, 26 July 2021, 20:40:50 »
Thank you.No tools needed to install clear cover
Offline RivieraS
  • Yutop
I am very confused.
Hi.What are you confused?
Offline Mad_Rhetoric
« Reply #9 on: Wed, 04 August 2021, 08:49:56 »
You are the same OP that created SA Prism that never went anywhere and you never communicated it. Is this going to be the same thing? Where you don't follow through?
Offline General_Pretzel
« Reply #10 on: Fri, 06 August 2021, 01:00:34 »
Damn. Someone needs to take a chill pill. Just because you run an IC for a product on a random internet forum doesn't mean OP owes you anything. If they didn't want to run a project / lost interest themselves and they didn't take your money, they don't have to do diddly squat.
Offline growler
« Reply #11 on: Fri, 06 August 2021, 04:58:17 »
I mean, I like it. Please follow through indeed, but the price needs to be lower to get good traction IMHO.
I wouldn't hold one binned IC against you if no financial damage was incurred. Then again, it perhaps does dent people's confidence in your ability to deliver if you do it a few times.
Anyway, GLWIC !!
