Author Topic: Wireless keyboard with this shape  (Read 1990 times)
Offline Joel.dela
« on: Sun, 25 July 2021, 09:11:57 »
I'm new to mechs. Does anyone know where I can get a wireless keyboard that is the shape/layout of the ones in the first two pictures?
The third pic is one option I'm thinking of buying but the problem is I don't really like shape/layout of it.. it doesn't look as cool, kinda.. crowded.
Offline MedicatedThembo
Re: Wireless keyboard with this shape
« Reply #1 on: Sun, 25 July 2021, 14:03:29 »
the layout you're looking for is known as a TKL. basically just a full-size board with the numpad (tenkey) cut off (tenkey-less, TKL). the one on the bottom is a 75% layout. personally i'd recommend the MKB87 https://www.aliexpress.com/item/4001232137080.html if you're looking for a kit to fill with your own switches and keycaps, or the keychron k8 https://www.aliexpress.com/item/4001232137080.html if you're just looking for a board that's ready to go.
Offline Joel.dela
« Reply #2 on: Sun, 25 July 2021, 16:21:42 »
i think you posted the same link twice
