Author Topic: [IC] Typ 65+ - a 65% keyboard with left macro cluster | GB thread is up now  (Read 102477 times)
Offline Nles
Re: [IC] Typ 65+ - a 65% keyboard with left macro cluster | (1/9) 2nd Proto reveal
« Reply #50 on: Thu, 02 September 2021, 05:18:25 »
Since you already have your 2nd proto on-hands, anything to say about the possible lead time? :D
For the lead time we are looking at 7 to 8 months if everything goes smoothly  ;)
do note that this is still an estimate, we will have a better and more accurate timeline only once production starts
It's gonna be a painful wait of 7-8 months~
Offline handmademedal
« Reply #51 on: Thu, 02 September 2021, 06:33:34 »
nice blocker placement!
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #52 on: Thu, 02 September 2021, 20:59:13 »
Pretty cool! I'm in!
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #53 on: Sun, 05 September 2021, 01:55:16 »
very nice, super excited
Offline wt1155
« Reply #54 on: Sun, 05 September 2021, 21:13:24 »
Thank you all for the active participation and support in the stream on Friday and Sunday
We will be providing more of these info soon:
  • Typing test for both tactile and linears gasketed and top mounted
  • Build streams and reviews from keyboard streamers and youtubers
  • Irl pictures of our carrying case once it arrives
  • More photos of our proto colours under natural and different lighting conditions and also pic of the finalized jade ano colour chip
  • Collabs with other makers eg: artisans/cables
« Last Edit: Sun, 05 September 2021, 21:14:58 by wt1155 »
Offline Gvalch_ca
« Reply #55 on: Mon, 06 September 2021, 06:41:21 »
Really like that your hotswap PCB supports only the stepped caps lock. Stepped caps is the way to go!
Lead Keyboard Cringeneer.
Alps and Space Invaders enthusiast.
Offline Dunne
    • Dunne
« Reply #56 on: Mon, 06 September 2021, 07:18:35 »
So in for this!
Offline touch
« Reply #57 on: Fri, 17 September 2021, 17:06:58 »
Any chance for split space support?
Edit: Found the answer on discord.
« Last Edit: Sat, 18 September 2021, 08:14:36 by touch »
Offline munda
  • Formerly kcao
« Reply #58 on: Thu, 23 September 2021, 08:40:03 »
Looks great! Will definitely try to get my hands on one when groupbuy starts  ;D
Offline jagger27
  • ne 1.5U supers???
« Reply #59 on: Thu, 23 September 2021, 16:46:17 »
I wonder how the Jade version would look with GMK Kaiju.
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
My bank account is so ready for this. Congrats for all your hard work and all the luck for the GB! I'm definitely in.
Offline Kinesiologist
for sure am in
Offline wt1155
Hey Guys,
We have finalised the pricing for the kits and also the GB format and dates.
We have also added the Nephrite Jade ano chip colour sample and the source of inspiration for this colour
Also added upcoming build stream by reviewers
« Last Edit: Sat, 16 October 2021, 12:31:13 by wt1155 »
Offline Kokukenji
Really great layout and can't wait for the GB. On one side, hope people snooze enough on this for me to get in on the GB  :D
Offline caffeinated.rik
Very excited for this one wishing you luck! Is there an FE with chili oil?
Offline wt1155
Added latest build stream of the second prototype by Jae  :thumb:
Offline SmitH1y
This is hawttttt
Offline wt1155
Re: [IC] Typ 65+ - a 65% keyboard with left macro cluster | GB link is up
« Reply #67 on: Wed, 03 November 2021, 23:04:28 »
GB thread link and info is up now  ;)
« Last Edit: Wed, 03 November 2021, 23:06:01 by wt1155 »
Offline Totoro
Re: [IC] Typ 65+ - a 65% keyboard with left macro cluster | GB thread is up now
« Reply #68 on: Thu, 04 November 2021, 03:42:26 »
Typ 65+ by axiφm studios
GB Thread
renders by motohiro
Website
Join our discord group
Follow us on Instagram
Updates :-
17/10 - We have finalized the pricing of our kits here are the details:
S = Kitting with Solder PCB and HS = Kitting with Hotswap PCB
There will also be build stream of the proto boards by:
 Taekeyboards: https://www.youtube.com/channel/UCllGwtW6scxAjM28fIgEozg
 Diego from Lightning Keyboards: https://www.twitch.tv/lightningkeyboards
 Jae from Prototypist Keyboards: https://www.twitch.tv/jae_prototypist
Design
The design is inspired from the JER mini layout with a functional blocker. Featuring a seamless case to maintain and clean and minimal look. The board feature 2 type of mounting system with top mount and gasket mount configuration. The blocker can function as layers indicator with LED soldered and a diffuser or as cosmetic with brass badge insert.
Typ 65+, a 65% layout with left macro cluster and chamfered edges.
renders by motohiro
Low front typing height and cherry boards inspired front lip design, for comfort and a homage to vintage design.
renders by motohiro
renders by motohiro
It also features a clean and minimal design by having hidden brass weight to deliver a more consistent sound profile across the board while still providing a load to it.
Garnet Red
Spinel Grey
Nephrite Jade
V2 Proto pics
Finalized Jade Ano Colour
Fun Fact:
Nephrite Jade is inspired from the R34 GTR Millennium Jade paint  ;)
Case specifications:-
•   Designed by 14x71
•   CNC aluminum 6063
•   65% layout with left macro cluster design
•   6 degree typing angle
•   Dual mount configuration: Top mount or Oring gasket mount
•   17.7mm front lip height - centred USB-C port
•   Colors:- Nephrite Jade, Spinel Grey, Garnet Red (Top) - Silver, Black (Bottom)
PCB specifications:-
•   Designed by Kopibeng
•   Comes in solder and hotswap variant
•   Solder pcb will have universal layout support 6.25u, 7u, ISO, a universal plate file will be provided later on if you wish to use 6.25u bottom row
•   PCB compatible with QMK,VIA and VIAL support
•   USB-C daughterboard (ai03 unified c3 db)
•   OTD 356 mini style PCB flex cut and relief cut
•   LED indicator (if soldered) for layers but there will also be firmware file for lock keys instead if there is demand
•   Red solder mask
Solder and Hotswap PCB pics
PCB labels for quality of life improvement
PCB supported layout for solder and hotswap
Exploded view:
Gasket Mount
Top Mount:
2nd Proto Build Stream
•   Taekeyboards: https://www.youtube.com/channel/UCllGwtW6scxAjM28fIgEozg
•   Diego from Lightning Keyboards:
    Configuration: Mx hyperglide blacks with half cf plate
•   Jae from Prototypist Keyboards:
    Configuration: OP blacks with full cf plate, ISO layout
First Proto Typing Test
I've some feedback on the candle being in the typing test video. The reason behind is because the wooden wick creates a faint crackling ambience sound to validate that the recording is indeed unedited, not the other way round.
Switches: Cherry hyperglide blacks /w 63.5 slow springs (lubed and filmed)
Keycaps: GMK Burgundy
Mounting: Top mount /w carbon fiber half plate
Switches: Vintage cherry mx clears /w 63.5g 22mm springs (lubed and filmed)
Keycaps: enjoyPBT G81-SAV
Mounting: Gasket mount /w carbon fiber full plate
Our first prototype does not feature OG cherry front lip which will be added on the 2nd prototype.
Plate Supported Layout:-
Kitting:-
•   CNC top and bottom case (Anodized)
•   Brass weight (Sandblasted)
•   Brass blocker and PC Blocker (Both sandblasted) -Tentative-
•   Carbon fiber twill plate (Half/Full)
•   Screws, rubber gasket strips, LEDs and etc.
•   Custom hard carrying case
Sales format:-
•   Groupbuy format (FCFS/Raffle)
•   200-300 units
•   Price: TBD, tentative $390
Current road-map:-
•   Make first prototype case and PCB
•   Review and revise design and case study on current prototype case
•   Make interest check and collect data
•   Make 2nd prototype case, anode chip and PCB 29/7 - 2nd prototype case and pcb confirmed and currently in production.
•   Update IC post with new prototype and builds
•   Finalize design and kitting
•   Finalize pricing and sales format
Our challenges and how we react to it:-
•   Possible anodization color did not live up to expectations?
To overcome such challenges we will try to minimize such uncertainty by placing 2nd prototype and anode chip to color check against our renders).
•   Delay in shipping and bad product being handled to doorstep which will further delay the GB?
We have placed our own representative to facilitate local manufacturer processes to minimize risk and ensuring manufactured goods are to what we expected before shipping to our doorstep for further QC and fulfilment.
Frequently-asked-questions :-
Q: Is there any hotswap PCB to be made available?
A: Currently we have no plans to provide for hotswap PCB. 29/07 - Due to demand in hotswap pcb, we are currently looking into.
Q: Is the LED programmable, if so isit RGB?
A: No it’s not RGB, you would have to solder in the LEDs (we will provide only white LEDs). Else, you could just install with the brass blocker if you prefer non luminated.
Q: How long is the fulfilment time or groupbuy dates?
A: Currently we are looking to set up the groupbuy around mid Nov or early Dec. As for the fulfilment dates would provide later after we set up our 2nd prototype.
Q: Where are you guys based?
A: We are based in Penang, Malaysia. and our designer is based in Bali, Indonesia.
For more updates please follow our Discord / Instagram / website for any development.
Website
Special thanks to :-
Beamingrobot from monokei
Lbaron from Smith and Rune
Kaster and YZ from Hex Keyboards
Motohiro for the renders
Keebmunity, Kopibeng, IMKG community, jebbra, itsundone, zedbraxmen
Everyone who has supported us this far, Thank you
i like red
