Author Topic: When I use the trackpoint it gets stuck in a corner.  (Read 90146 times)
Offline yzdnegel
« on: Mon, 26 July 2021, 09:42:03 »
So I wired a trackpoint to my keyboard (microcontroller). I just assumed that the pinouts were the same as another trackpoint: https://geekhack.org/index.php?topic=113839.0
The problem that I currently have is that when I use the trackpoint it just goes down either to the bottom left or top right corner and gets stuck there until I unplug it. My QMK code looks like this (copy-pasted from QMK:
Code: [Select]
#ifdef PS2_USE_USART
#define PS2_CLOCK_PORT  PORTD
#define PS2_CLOCK_PIN   PIND
#define PS2_CLOCK_DDR   DDRD
#define PS2_CLOCK_BIT   5
#define PS2_DATA_PORT   PORTD
#define PS2_DATA_PIN    PIND
#define PS2_DATA_DDR    DDRD
#define PS2_DATA_BIT    2
/* synchronous, odd parity, 1-bit stop, 8-bit data, sample at falling edge */
/* set DDR of CLOCK as input to be slave */
#define PS2_USART_INIT() do {   \
    PS2_CLOCK_DDR &= ~(1<<PS2_CLOCK_BIT);   \
    PS2_DATA_DDR &= ~(1<<PS2_DATA_BIT);     \
    UCSR1C = ((1 << UMSEL10) |  \
              (3 << UPM10)   |  \
              (0 << USBS1)   |  \
              (3 << UCSZ10)  |  \
              (0 << UCPOL1));   \
    UCSR1A = 0;                 \
    UBRR1H = 0;                 \
    UBRR1L = 0;                 \
} while (0)
#define PS2_USART_RX_INT_ON() do {  \
    UCSR1B = ((1 << RXCIE1) |       \
              (1 << RXEN1));        \
} while (0)
#define PS2_USART_RX_POLL_ON() do { \
    UCSR1B = (1 << RXEN1);          \
} while (0)
#define PS2_USART_OFF() do {    \
    UCSR1C = 0;                 \
    UCSR1B &= ~((1 << RXEN1) |  \
                (1 << TXEN1));  \
} while (0)
#define PS2_USART_RX_READY      (UCSR1A & (1<<RXC1))
#define PS2_USART_RX_DATA       UDR1
#define PS2_USART_ERROR         (UCSR1A & ((1<<FE1) | (1<<DOR1) | (1<<UPE1)))
#define PS2_USART_RX_VECT       USART1_RX_vect
#endif
I also used alonswartzs guide for trackpoints and made a reset circuit like he did: https://github.com/alonswartz/trackpoint
Thanks in advance!  :D
Offline humanplayer2
Re: When I use the trackpoint it gets stuck in a corner.
« Reply #1 on: Tue, 22 August 2023, 01:41:12 »
Did you get the issue resolved? a
Offline darkwitchclaire
« Reply #2 on: Mon, 29 January 2024, 17:14:00 »
Sometimes that happens just from the trackpoint having to correct itself, reseating it usually works.
