Author Topic: Can buckling spring tension be increased by stretching the spring?  (Read 3189 times)
Offline phototristan
    • https://www.youtube.com/phototristan
I've always wondered, can buckling spring tension be increased by pulling on and stretching the spring? Would that work?
Offline audioave10
« Reply #1 on: Sat, 28 August 2010, 14:27:07 »
I would worry about warping the spring slightly to one side. Might cause an inconsistant click. I worked with metals for many years. The spring is so small that you can't always predict how it would react.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline ch_123
« Reply #2 on: Sat, 28 August 2010, 14:48:51 »
Im pretty sure that this has been tested out and failed miserably.
The whole thing depends on the dimensions of the spring being within certain tolerances, relative to the key travel, the size of the hammer, and how much force the hammer must strike whatever contact mechanism is underneath it. If you start playing around with it stops working.
For example, while the Model F springs are the same length, they have more coils, and consequently don't work if you put one on a Model M hammer and put one in a Model M. The opposite also doesn't work.
« Last Edit: Sat, 28 August 2010, 14:51:53 by ch_123 »
« Reply #3 on: Sat, 28 August 2010, 16:18:06 »
Makes sense. Thanks guys.
Offline Morning Song
« Reply #4 on: Sat, 28 August 2010, 16:29:11 »
The only way i think people have succeeded in tweaking the feel of a BS keyboard has been through boltmodding, which as i understand, dampens some of the noise and 'tightens' the feel. i'm not sure if it's possible to do the reverse.
Clicky keyboards and big trackballs forever!
Keyboards:
Buckling Spring: IBM Model M 1391401, Unicomp Customizer 104, PS/2 modded IBM Model F Terminal 6110668 (current favorite)
Cherry: Filco Majestouch 105 Blue NKRO w/ doubleshots
ALPS: Dell AT101W Black SNAFU (Silent No-longer; All Fukka\'d Up), Siig Minitouch KB1948 Geek Hack Spacesaver edition, Focus FK-2001 w/ WinKeys+XM Alps
Rubber Dome: Belkin F8E887-BLK, Silitek SK-6000, Logitech Internet Navigator Keyboard
Works in Progress:
Prism ATX N9 Keyboard w/ Fukkas (Clickleaf Donor), Cherry G80-8113HRBUS-2/02 Brown NKRO, Cherry G81-7000HPCUS-2/02 (Doubleshot donors), Unicomp Customizer 101 (Springs donor, needs boltmod)
Pointing Devices:
Kensington Expert Mouse 7, Wacom Intuos3 6x8 w/ classic pen
Looking to buy/trade for:Dolch Cherry keycaps, Northgate Omnikey (With Fkeys on top, or both top & left), IBM Model F AT
« Reply #5 on: Sat, 28 August 2010, 16:31:41 »
The way to increase the tension of a spring is to compress it fully, and that is usually done as a step during manufacturing.
Offline ch_123
« Reply #6 on: Sat, 28 August 2010, 16:45:46 »
Ah, the Model F's spring is like 1mm longer than the M's one.
Offline wellington1869
« Reply #7 on: Sat, 28 August 2010, 18:18:11 »
Quote from: phototristan;217652
conversely, making it softer by squishing spring?
I dont think anyone has done squish/stretch tests, have they? any volunteers so we have a definitive experiment for that?
using: ms 7000/Das 3
« Reply #8 on: Sat, 28 August 2010, 18:58:30 »
Quote from: Morning Song;217681
How does bolt modding change the feel? I'm not clear on how that would change the feel nor even dampen the noise.
Offline JBert
« Reply #9 on: Sun, 29 August 2010, 05:16:00 »
Quote from: phototristan;217724
The rivets which clamp front and back plate together may break after a while, which means that the springs will force the plates apart. As a result, a spring will buckle differently because it has more distance between the plates.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline TheSoundofTyping
« Reply #10 on: Sun, 29 August 2010, 05:41:05 »
No OP, taking a spring after it has finished being made and then stretching it only weakens the spring.  It's the opposite of what you want.
"To my loyal butler, You There, for his decades of service, I leave a pittance, to be paid in twenty equal installments of one-twentieth of a pittance each."
