Author Topic: [IC] Yoretech 65% Case  (Read 6007 times)
Offline Salonias
« on: Tue, 03 August 2021, 10:55:11 »
Hello! This is Trenton from Yoretech, and this is our first case and IC!
273425-0    273428-1
Many types of designer and custom cases like to add brass to the bottom for decoration and a bit of extra weight. I had an idea to make that material more prominent in the design, and clearly visible from the sides, front, and back. These thin bars provide a nice solid weight to the keyboard, and a bright color that can be used in synergy with all sorts of palettes and designs beyond the red shown here.
273431-2    273434-3
Each support bar also features three rubber support strips that provide a solid grip to whatever surface you set your board on, and equally distribute the weight of the board so that even with the extra weight, it poses no threat to the surface it's placed on.
273437-4
Thank you again for reading! As mentioned in the subject head, this is a standard 65% pcb compatible tray mounted case, and comes in a whole range of colors. We would love to put this case in front of you guys as soon as possible! If you're interested in making this happen, or have some questions about the design, let me know here or by answering this questionnaire. https://docs.google.com/forms/d/e/1FAIpQLSfwGRjhGjCMKK2b-QMa-ud1RJ9YyvVxtrftqMf6TSWuStbceg/viewform?usp=sf_link
« Last Edit: Tue, 03 August 2021, 13:29:40 by Salonias »
Offline wahfuhls
Re: [IC] Yoretech 65% Case
« Reply #1 on: Tue, 03 August 2021, 11:25:41 »
reserved
Offline TheInverseKey
  • You can run but you cannot hide!
« Reply #2 on: Tue, 03 August 2021, 11:26:57 »
[ Specified comment is not available ]
Offline Salonias
« Reply #3 on: Wed, 15 September 2021, 16:45:11 »
Hey everyone, thank you for your responses and interest! We have been getting some good feedback in regards to the case, and we were hoping to narrow some things down to really help give you guys something special. We want to set quality as the foremost of our priorities, and as such have been tweaking the design and production process to both make the case nicer, and easier to machine. Here are some of the things we have addressed, and some we could use your thoughts on.
1. The Brass: When ordering metals for our prototype, we chose a brass alloy that was easily tarnished after extended exposure to oils and oxygen. We have since chosen a suitable replacement, that will not only retain that same brightness, but also not require the addition of any sealers or coats.
2. Central Support: Some requests stated that they would like the option of having the center standoffs removed. As we continue the development of the web page the store will be hosted on, we will be certain to add an option to order a case without the two center plate supports.
3. The Rubber: Currently the bottom of the case is help up by several rubber strips, that are friction fit into several grooves. Due to the nature of the machining method, these grooves are round at each end, not square, which makes some of the strips themselves look forced, uneven,  or out of place. There are several approaches to the problem of making this nicer, but we value your input greatly. If you would be interested in a change to the rubber supports, visit this link to give us your feedback. https://docs.google.com/forms/d/e/1FAIpQLScUpGnhBQchACjAP5lP-IkZl0yhrpsvcLflkcQ7qMsq6c6iIg/viewform?usp=sf_link
Thanks again for taking the time to let us know how we can continue to improve and refine our craft.
Edit: Forgot to mention we are also rounding out the topside edges, will get some pictures to show when we got it the way we like.
« Last Edit: Wed, 15 September 2021, 16:47:01 by Salonias »
