Author Topic: media/DAW icons (play/pause record loop home end)  (Read 4153 times)
Offline xmobotx
« on: Thu, 12 August 2021, 00:52:14 »
I know there's a selection of these stock icons you can get from signature plastics.  I got some to check them out.
What I'd like to see is kitting options themed along with group buys.  Much like KAM playground. {I might just buy a couple of those kits}
Mainly, I'd like to use a macro pad as a control surface for my DAW & I'm certain that there are those who would also be interested if they were aware.  What could be cool is 2u POS keys for common functions like play & record for instance.
   maybe something fancy ~A little more than the common circle or triangle?
Is there just not enough interest to offer these kinds of kits?
Offline xmobotx
Re: media/DAW icons (play/pause record loop home end)
« Reply #1 on: Thu, 12 August 2021, 17:54:29 »
lol, i guess that says it all
Offline Faceman76
1800s and heavy springs
Offline xmobotx
« Reply #3 on: Fri, 13 August 2021, 03:03:45 »
 :thumb: hey thanks
I got these from PMK:
play, pause & stop are redundant w/ my DAW since space is the keyboard shortcut for all three.  Im thinking today about getting a capsunlocked cu7 & using a play/pause.
I'd like it to be cool though ~not just dye-subbed black & w/ bigger macro pads like octopad, the 2u thing would be cool for play & record.  I even think a vertical 2u for adding a track or toggling the mixer.  Nothing really covers all the bases
