Author Topic: [GB] DCS Alps Pingmaster // Replacement keys shipped to vendors  (Read 41215 times)
Offline Fredington
    • Instagram
« on: Mon, 16 August 2021, 07:50:43 »
Hi all,
Welcome to the GB for DCS Alps Pingmaster, an Alps-specific set based on the legendary IBM Pingmaster from the 1980s:
**Please note that the renders are done in Cherry profile, which is quite similar to but not exactly the same as DCS. Nevertheless, they should give you a good idea of how the final set will look like.
Specifications
Manufacturer: Signature Plastics
Profile: DCS 1-1-2-3-4-4
Material: PBT, except longer spacebars and relegendables
Legends: Dye-sublimated top legends w/ pad-printed front side legends
Colors: Stock SP PBT colors
Switch Mount: Alps
Stabilizer Mount: MX
**Please note that these caps are for Alps/Matias switches only and are not compatible with MX-style switches. Stabilizer mounts however, will be MX-shaped.
GB Details
The GB will run with the following vendors from August 16 to September 13 and is estimated to ship in Q1 2022.
US: Mechs&Co
CA: Desk[H]ero
UK: Proto[Typist]
EU: MyKeyboard
AS: zFrontier Chinese and International
OC: Daily Clack
Kits
Base
Please note that the longer spacebars will be made in ABS due to warping. Front legends will be pad printed.
JIS & macOS
I know this doesn't cover true JIS layouts, but we wanted to focus compatibility on common Alps layouts while also being constrained by the key sizes that SP currently has due to costing. Also includes macOS bottom row swaps.
Spacebars & 40s
Again, the longer bars will be ABS. Includes complete support for hiney's H60 PCB, as well as 3-key 40s support.
Relegendables & Ortho
For those who want that authentic Pingmaster look. This kit is also designed to be able to cover an ortho board. Due to shrinkage, all relegendable keys will be ABS.
Accents
Renders by Kingk22
TKC1800
TGR Jane
Bean by Kingk22
Acknowledgements
Special thanks to Franco, Kingk22, konstantin, KidViddy, and all the vendors, especially Mike from Mechs&Co.
Social Media
Finally, if you'd like, you can follow me and my other projects on my IG @fredington.
« Last Edit: Mon, 15 August 2022, 12:34:19 by Fredington »
Offline Fredington
    • Instagram
Re: [GB] DCS Alps Pingmaster // August 16 - September 13
« Reply #1 on: Mon, 16 August 2021, 07:57:20 »
4.22.22
ABS to PBT color matching (longer spacebars and relegendables) complete
4.28.22
PBT molding complete, start of sublimation phase
6.1.22
Production complete, packing commencing.
« Last Edit: Thu, 02 June 2022, 21:11:24 by Fredington »
Offline justinhigley
« Reply #2 on: Sat, 21 August 2021, 19:44:42 »
Looks great! I'm in for everything.
Hope there's still enough alps interest to make things like this a reality.
Offline IO Sam
    • IO Sam Hub
« Reply #3 on: Mon, 23 August 2021, 15:17:17 »
Order is in!  :thumb:
Thank you for keeping the Alps flame alive!!!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #4 on: Tue, 24 August 2021, 15:08:23 »
Offline joshuarubin
« Reply #5 on: Tue, 24 August 2021, 15:13:09 »
:fingers crossed:
Come on people, make this happen!
Offline Fredington
    • Instagram
« Reply #6 on: Tue, 24 August 2021, 16:04:08 »
:fingers crossed:
I think this a is a pretty good start so I’m not too worried!
Offline shansoft
« Reply #7 on: Tue, 24 August 2021, 17:35:09 »
:fingers crossed:
I bought 2 set myself....
It would be fine since this is only the first week  :D
Anyone know if there are MX to Alps stab adapter? Some old board I have only have the traditional alps stab, not sure if Costar stem will fit properly.
Offline konstantin
  • Formerly constexpr
« Reply #8 on: Wed, 25 August 2021, 10:42:17 »
Really hoping this does well! Awesome set.
Offline loud_asian
« Reply #9 on: Sat, 28 August 2021, 17:45:01 »
:fingers crossed:
https://geekhack.org/index.php?topic=112117.msg3047146#msg3047146
Offline shansoft
« Reply #10 on: Sun, 29 August 2021, 01:12:51 »
:fingers crossed:
Thank you so much!!!
Offline AeternusCo
« Reply #11 on: Mon, 30 August 2021, 23:24:32 »
I'd love to see some 40% boards get alps support now, very cool set
Offline tpec
« Reply #12 on: Tue, 31 August 2021, 05:16:26 »
Got my set in. Can't wait ;D
Offline Genericusername56
« Reply #13 on: Wed, 01 September 2021, 07:22:22 »
Would base+JIS cover a standard ISO layout? I guess so, even though the legends will be incorrect?
How far from MOQ is this?
Offline Fredington
    • Instagram
« Reply #14 on: Wed, 01 September 2021, 08:24:33 »
That’s correct. Updated numbers will be posted shortly. We’re about 50% to MOQ but JIS/macOS is struggling a bit.
Offline dvorcol
« Reply #15 on: Wed, 01 September 2021, 17:47:17 »
Offline Howgii
« Reply #16 on: Thu, 02 September 2021, 16:22:53 »
Do you know if the alps mount for the iso enter is rotated or not?
« Reply #17 on: Thu, 02 September 2021, 22:50:43 »
It is not rotated on DCS Alps Yuri. I'd assume the same for this set.
Offline Fredington
    • Instagram
« Reply #18 on: Fri, 03 September 2021, 11:50:33 »
Actually, according to Melissa they can be either. I assumed people would want the vertical orientation. If this is not the case, please speak up!
Offline Howgii
« Reply #19 on: Fri, 03 September 2021, 11:54:43 »
It don’t own an iso alps board yet but I do plan on building one. So others will have to vote for or against the rotation of the mount,and I’ll design my pcb accordingly
Offline joshuarubin
« Reply #20 on: Fri, 03 September 2021, 12:25:11 »
hah, enjoyment of alps is a labor of love
Offline Fredington
    • Instagram
« Reply #21 on: Fri, 03 September 2021, 12:31:54 »
Actually, I misunderstood your question and Melissa's answer. Here is a diagram of the options for the switch mount:
Unless people speak up regarding a preference for the orientation on the right, I'll be proceeding with the horizontal orientation on the left.
« Last Edit: Fri, 03 September 2021, 18:16:03 by Fredington »
Offline Applet
« Reply #22 on: Fri, 03 September 2021, 18:03:15 »
If comparing with older alps keycaps, I'm pretty sure the right one is the common rotation for ISO enter switches, not saying this is necessarily the best approach tho. Check for example alps64 or plain60 alps edition, it does not have any support for horizontal switches for ISO enter.
EDIT: You could argue that the left one may be more common in PCB's that have both MX and Alps support, but, there are already three common-ish vertical positions for ISO enter, and I'd personally appreciate if we did not get a fourth common ISO-enter position/rotation. :D Yuri has the left rotation? Is there any other new alps-set from SP that does it the same way?
« Last Edit: Sat, 04 September 2021, 03:59:33 by Applet »
Offline Yakbats
« Reply #23 on: Sat, 04 September 2021, 11:36:37 »
I just finalized a pcb design using the vertical orientation (the one on the right), since that is what I have seen on the vintage boards I've come across. So, vertical is my preference, and I hope that's how this set gets made :)
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
« Reply #24 on: Sat, 04 September 2021, 18:31:14 »
« Last Edit: Mon, 15 April 2024, 21:22:16 by FearsomeCubedWarrior »
Offline Fredington
    • Instagram
« Reply #25 on: Sun, 05 September 2021, 13:09:41 »
After further investigation, the ISO Enter switch mount will indeed be rotated (vertical).
« Last Edit: Sun, 05 September 2021, 14:05:20 by Fredington »
Offline chevykeeb
« Reply #26 on: Tue, 07 September 2021, 07:55:27 »
What would be the average thickness of the keycaps?
Offline dvorcol
« Reply #27 on: Tue, 07 September 2021, 12:42:27 »
Offline Fredington
    • Instagram
« Reply #28 on: Tue, 07 September 2021, 15:01:55 »
They’re about 1mm thick.
Offline kaworu
« Reply #29 on: Tue, 07 September 2021, 15:07:19 »
Hi, JIS & macOS kit buyer here.
That is good to hear, I'm planning on using a PCB based on Steezy60 (https://keebmeup.com/index.php?id_product=129&id_product_attribute=1856&rewrite=60-alps-pcb-ansi-aek-support-coming-soon&controller=product#/52-plate_add_on-no_plate_needed_0) and as far as I can see it has a vertical mount ISO Enter.
Offline Applet
« Reply #30 on: Wed, 08 September 2021, 01:23:28 »
Yeah, it supports the three common vertical ISO enter stem positions and PCB stabilizers is placed centered just like the MX-standard (I'm the designer). They are also open sourced and available here if you want to make it yourself: https://github.com/4pplet/Steezy60
Offline Fredington
    • Instagram
Re: [GB] DCS Alps Pingmaster // Closing Monday, Sept. 13
« Reply #31 on: Thu, 09 September 2021, 15:39:46 »
Hi all,
Just popping in here to remind everyone that this GB will be closing in a few days on Monday, September 13. If you're interested in this set, now is the time to pull the trigger! All kits will be made, so order with confidence.
I also wanted to say a special thank you to everyone who supported this set. You guys showed that the interest in Alps sets is not inconsequential, despite initial doubts at the price per key of this set. Hopefully, this can pave the way for more Alps sets in the future.
« Last Edit: Thu, 09 September 2021, 15:41:46 by Fredington »
Offline TjarleN
« Reply #32 on: Thu, 09 September 2021, 23:21:35 »
Glad to hear that. :)
Offline Fredington
    • Instagram
« Reply #33 on: Sun, 12 September 2021, 20:41:22 »
LAST CALL! Closing tomorrow!
« Reply #34 on: Sun, 12 September 2021, 20:55:13 »
« Last Edit: Mon, 15 April 2024, 21:21:18 by FearsomeCubedWarrior »
Offline Friendship
« Reply #35 on: Mon, 13 September 2021, 10:27:32 »
YEEHAW! Thanks for running this beautiful set!
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline Define
« Reply #36 on: Mon, 13 September 2021, 12:34:07 »
Also pulled the trigger on base and accents. Alps caps are rare.
Curious about the final numbers though!
Offline The0rigina1
  • fumoposting
« Reply #37 on: Mon, 13 September 2021, 13:42:36 »
Bought base and relegendables, cuz I don't use JIS (also not full JIS), the accent kit doesn't look the part imo (and it ruins the retro grey beige vibe),
and I don't really plan on using this great retro on anything other than a tkl or full size  :D
Also, if you don't mind, would you share the final sales number? just curious, thanks  :thumb:
Offline Fredington
    • Instagram
« Reply #38 on: Mon, 13 September 2021, 14:00:00 »
It will close tonight and take a few days to tally everything.
Offline gaunt
Re: [GB] DCS Alps Pingmaster // GB Closed
« Reply #39 on: Wed, 15 September 2021, 14:11:10 »
RIP, 2 days too late to find this :( - there should be some newsletter for Alps-related group buys, I don't pay enough attention anymore since almost everything is MX-related. Looks like an awesome project, best of luck to you.
Offline joshuarubin
« Reply #40 on: Wed, 15 September 2021, 14:19:28 »
DCS 9009 has an alps kit and is running now. https://cannonkeys.com/collections/featured/products/dcs-9009
Offline Fredington
    • Instagram
« Reply #41 on: Wed, 15 September 2021, 14:29:57 »
There will be extras early next year.
Offline gaunt
« Reply #42 on: Wed, 15 September 2021, 15:07:47 »
Oooh, I'll need to keep an eye out then  ;)
Offline dvorcol
« Reply #43 on: Thu, 16 September 2021, 12:54:16 »
« Last Edit: Tue, 21 September 2021, 15:06:00 by dvorcol »
Offline TjarleN
« Reply #44 on: Thu, 16 September 2021, 14:37:22 »
Wow the numbers doubled in the last week.
Pretty solid after the slow start.
Offline The0rigina1
  • fumoposting
« Reply #45 on: Thu, 16 September 2021, 21:13:35 »
Looks good, especially without extras  :thumb:
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #46 on: Tue, 21 September 2021, 07:58:22 »
Is there any chance of a future run in MX?
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #47 on: Tue, 21 September 2021, 08:04:52 »
Thank you for running this set!
Offline Fredington
    • Instagram
« Reply #48 on: Tue, 21 September 2021, 08:22:16 »
Of course there’s a chance ;)
Offline dvorcol
« Reply #49 on: Tue, 21 September 2021, 15:05:38 »
<-- without extras
