Author Topic: Soarer Wyse Converter Troubleshooting  (Read 3528 times)
Offline BrooklynTony198
  • A person was here.... Now its only keyboards.
« on: Tue, 17 August 2021, 00:19:27 »
I own a Wyse PCE 840358-13 keyboard. I just finished restoring it, and have made a converter according to Soarer's instructions. (Which can be found here: https://geekhack.org/index.php?topic=52597.0) However, when I plug my board in, all it does is turn on the lock lights:
274419-0
In my mind, this obviously means I hooked up the power correctly. However, using HID Listen shows the converter isn't giving any codes at all. Which means my converter isn't even detecting anything is there.
I have my converter wired up as so:
274421-1
274423-2
Any ideas why its not working?
  IBM Model M5-2        IBM Model F XT       Asteria60             AntaresTKL           Scorpii9
Re: Soarer Wyse Converter Troubleshooting
« Reply #1 on: Fri, 20 August 2021, 03:03:38 »
I can't help but have moved the thread to MST! so hopefully someone who can will see it.  A clear pic or written list of which colour wire goes to which pin on the Pro Micro(?) would be good :)
