Author Topic: Keycap set question  (Read 4963 times)
Offline Parzi
  • Formerly 'Prezi'
Keycap set question
« on: Fri, 20 August 2021, 12:08:11 »
I recently bought these keycaps https://kbdfans.com/products/dsa-ergo?variant=21329987141690 and was wondering why it came with an extra set of F and J, I have seen this in a few sets and thought it was because one set would have the bump and one wouldn't. But both of my F and J keys were flat with no bump so now I am confused at the real reason.
Offline AstralYT
Re: Keycap set question
« Reply #1 on: Fri, 20 August 2021, 12:10:49 »
Maybe the 2nd F and J have deeper scoops?
Sent from my GM1917 using Tapatalk
Offline Parzi
  • Formerly 'Prezi'
« Reply #2 on: Fri, 20 August 2021, 12:12:27 »
That is possible I guess. I didn't compare them directly to each other. I will have to check that out. I just compared them enough to know neither had the "bump" can't remember the official term for that.
« Reply #3 on: Fri, 20 August 2021, 12:12:30 »
There are a few versions of these homing keys - some have bumps, dots or big dips in the top of the cap.  If they are the same there is no point having two sets...
Offline Parzi
  • Formerly 'Prezi'
« Reply #4 on: Fri, 20 August 2021, 14:08:23 »
Glad to know I am at least not crazy about the fact that I have two similar sets. But yeah when I get home I am going to check if there is a bigger dip on one of them.
« Reply #5 on: Sat, 21 August 2021, 03:38:27 »
I have few DSA sets, but from memory you (used to) get an F and J with no scoop at all (perhaps for alternative layouts, for which DSA profile is ideal, where F/J are not the homing keys), and an F/J with scoops.
Personally I prefer bars, but do tend to use the scoops if they are available.
Offline Parzi
  • Formerly 'Prezi'
« Reply #6 on: Mon, 23 August 2021, 10:41:11 »
I also prefer bars, but after I got home and checked my keys the other two F and Js have really deep scoops and the two I put on to test my keyboard does not. So now I know to switch those two out for the scoops.
