Author Topic: Filco white: molded texture?  (Read 1711 times)
Offline Jalal
« on: Mon, 30 August 2010, 13:18:01 »
Hi :)
Does the white Filco also has the molded texture the black has?
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #1 on: Mon, 30 August 2010, 13:37:47 »
I am looking at both right now and I believe they do indeed have the same "molded" texture. However there is a chance that the coatings you might get may slightly differ, but the molded texture should be the same.
For all practical purposes though I would call them the same.
Hope that helps =)
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline Jalal
« Reply #2 on: Mon, 30 August 2010, 13:46:29 »
Thank you. As long as they feel the same then this is all i want to know. :)
