Author Topic: [IC] SA .AFK  (Read 5531 times)
Offline SadTeRrA
[IC] SA .AFK
« on: Fri, 27 August 2021, 18:02:11 »
Interest Check Form: IC FORM
WELCOME TO THE WORLD! There's an infectious outbreak that must be contained. Only our beloved hero can quarantine it off before it mutates. Azure Flame Kite from the .hack series is a beloved character, unlike my puns.
If you enjoy the theme, let me know. If you have feedback for it or me, let me know. Enjoy!
Profile: SA
Manufacturer: Signature Plastics
Kitting
Kitting Design:
I am looking to make purchasing simple. If you like the alphas I would like for you to have the ability to buy just those. 40's are something I asked many people about and looked at many sets. With their aid decided it would provide good coverage. If enough people request it I will make a proper bars kit. SP SA sets can be pricy and I wanted to keep everyone in mind without large compromises.
Colors:
Pantone564 C
Pantone 3255 C
Ral2010 Signal Orange
Ral2002 Vermillion
Note that all renders are simply used in order to visualize the set. These colors represent the actual colors that the set will use, and may be changed slightly as development goes on. Things like monitor calibration, compression, and room lighting can all affect the perception of the set colors. (credit:adi)
Renders:
Credit: U80 by Rama Works, Paragon by Artimis Design Studio, M0LLY by The Key Company, Nemui by Bachoo, and Maja by Vulcan. All renders done by me. Full album: https://imgur.com/a/IJV0A8O
To Do List:
Collect IC responses and include pertinent information
Finish Novelty Development and Post
Possible Deskmat
Redo kitting if required and apply feedback discovered from IC
Acquire & announce Vendors
Acquire & announce Collabs
Set GB Date
Start GB
Place order with Signature Plastics
Vendors:TBA
I would like to thank Cylent for the critical advice when it comes to kitting and being generally helpful.
matt for helping go over the 40s set.
r/keycapdesigners for helping with color selection.
r/dothack for help deciding on a name.
« Last Edit: Sun, 29 August 2021, 21:11:23 by SadTeRrA »
Offline Baka Bot
Re: [IC] SA .AFK
« Reply #1 on: Fri, 27 August 2021, 18:20:24 »
The images dont work.
Offline SadTeRrA
Re: [IC] SA .AFK
« Reply #2 on: Fri, 27 August 2021, 18:23:51 »
I'm working on a fix as fast as I can currently.
Fixed.
« Last Edit: Fri, 27 August 2021, 18:42:42 by SadTeRrA »
Offline vishydesigns
Re: [IC] SA .AFK
« Reply #3 on: Fri, 27 August 2021, 18:44:11 »
Looks great! Interested to see where this set goes GLWIC :thumb:
Offline LittleAad
  • Hello
Re: [IC] SA .AFK
« Reply #4 on: Fri, 27 August 2021, 23:31:37 »
what in the world happened to the renders  :eek:
Offline MrBingo
Re: [IC] SA .AFK
« Reply #5 on: Sat, 28 August 2021, 01:03:03 »
change in your rendering software (Blender) your camera to perspective instead of orthographic to fix your renders
« Last Edit: Sat, 28 August 2021, 01:08:02 by MrBingo »
Offline William_S_Jones
  • Best Prime Ever!!!
Re: [IC] SA .AFK
« Reply #6 on: Sat, 28 August 2021, 08:31:04 »
I love this keyset, the colorway gives it a great POP! Just 1 question, can you add blue spacebars to the 40s kit?
« Last Edit: Sat, 28 August 2021, 08:34:20 by William_S_Jones »
Offline SadTeRrA
Re: [IC] SA .AFK
« Reply #7 on: Sat, 28 August 2021, 21:11:56 »
Thank you much I didn't notice and am fixing the ones that have this issue.
Fixed everything with this specific issue will make better quality renders
I would love to break up the color monotony on this kit. I'm just not sure how because I want to keep it as reasonably priced as possible. I would like to do an alt bars kit or something that way people can choose the blue colors or orange but only if they garner enough attention. I will put the colors more places if it is reasonable thank you for the question.
« Last Edit: Sun, 29 August 2021, 21:12:44 by SadTeRrA »
