Author Topic: [KPICPRE] MKB87 V2 ISO DUAL MODE MECHANICAL KEYBOARD KIT  (Read 8659 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Wed, 01 September 2021, 21:33:39 »
MKB87 is one of the best value Mechanical keyboard kits under $100 on kprepublic.com.
Basic functions and SPECs are similar to the old MKB87 kits.
SPEC
  • Full RGB LEDs (support kinds of light effects)
  • Full Switch Hot-swappable sockets (both 3pin and 5pin switches)
  • Dual Mode (cable Mode+Bluetooth 5.0 Mode)
  • Type C(USB detachable design)
  • NKRO
  • Setting Memory Core
With MKB87 V2,  the factory designs software to control its RGB, key setting, Macros, etc.  It gives MKB87 more customization features.
Besides the software, MKB87 V2 use a new plastic case mould, offering more durable and solid protection and looks for MKB87 V2.
More images will be released in the future. (the following images are kind of prototype.
MKB87 V2 ISO kit is estimated released in late September or the beginning of October.
Join our discord server and follow the topic for pre-discount code.
« Last Edit: Wed, 01 September 2021, 21:35:32 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [KPICPRE] MKB87 V2 ISO DUAL MODE MECHANICAL KEYBOARD KIT
« Reply #1 on: Wed, 01 September 2021, 21:35:57 »
Offline s0ftcorn
« Reply #2 on: Thu, 02 September 2021, 18:53:24 »
Is this exactly what im looking for? Yes.
Did i make an account on this forum just to post this? Yes.
Will i buy this? Yes.
« Reply #3 on: Fri, 03 September 2021, 04:16:48 »
Will the configuration software be available for macOS, or only for Windows?
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #4 on: Mon, 06 September 2021, 02:43:30 »
The software is still in testing. We will update the info when it finished. :)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #5 on: Tue, 07 September 2021, 02:12:20 »
Just confirmed with the factory. the software is only on Windows platform. :(
