Author Topic: [IC] Overkill Deskmat - GB Last Day!  (Read 8110 times)
Offline unimaginablypatzer
« on: Sat, 04 September 2021, 02:02:19 »
In collaboration with Moshi Dokyo, we want to share you his "Overkill" artwork and make it a deskmat.
Actual deskmat below:
-One colorway only
-Size: 900 x 400 x 4mm
-Cloth Top
-Rubber Bottom
-Stitched Edges
*artist have agreed to proceed with the interest check and sale of his art (as deskmat)
[UPDATES]
*19/Sep - removed "Overkill" caption at the bottom part
*17/Oct - actual deskmat posted [GB] soon!
*20/Oct - Groupbuy opening 8pm GMT+8 (ends Nov16)
Product Page here: https://gcustomcables.com/collections/deskmats
IC Form: https://forms.gle/ithhBKuiisSC1k9D6
« Last Edit: Mon, 15 November 2021, 20:29:58 by unimaginablypatzer »
Offline SwitchKeys
    • SwitchKeys
Re: [IC] Overkill Deskmat
« Reply #1 on: Sat, 04 September 2021, 08:54:53 »
Have you just used the artists images and mashed them together (cropping out any watermarks), or are you the actual artist?
Google form to order as well? Seems sus
« Reply #2 on: Sat, 04 September 2021, 09:32:41 »
Hi, no and no. The artist and I have a mutual agreement. Because he's not into keyboards, so he doesn't have idea what to do (interest checks, groupbuys, geekhack, discord etc). You can check the original IG post of G Cables, the artist was tagged in the post :)
Offline HappyB0T
  • I'm a Piggie
« Reply #3 on: Sat, 04 September 2021, 21:25:02 »
Consider rephrasing that you are not "sharing" their art but actually working with them or collaborating with them. This was not apparent to me either based on the wording.
« Reply #4 on: Sat, 04 September 2021, 21:39:23 »
Hi, ok done. Thank you for the advise :)
Offline Bub
    • big bub's beepers
« Reply #5 on: Sat, 04 September 2021, 22:04:56 »
love to see this level of detail in a deskmat. i will say i'd prefer this without the text.
also, be aware that colors often saturate when printed on cloth, and that your samples might not turn out exactly like the png you have.
yellow is particularly bad for this.
anyway, get samples made up and work with vendor/manu on nailing the colors. GL!
« Reply #6 on: Sat, 04 September 2021, 22:26:57 »
Hi noted on this, thank you 🙏
Offline rondg
« Reply #7 on: Sat, 04 September 2021, 22:32:26 »
Please consider removing the text on the deskmat ;D
« Reply #8 on: Sun, 05 September 2021, 07:19:18 »
Will consider this thank you  :)
Offline Entity.
  • Entity#1234
« Reply #9 on: Sun, 05 September 2021, 07:42:47 »
If it didn't have text it would be a 100% buy for me
« Reply #10 on: Sun, 05 September 2021, 21:41:32 »
Noted on this  :D
« Reply #11 on: Sun, 19 September 2021, 06:37:01 »
[UPDATE] Removed "Overkill" text at the bottom part  :D
« Reply #12 on: Sat, 16 October 2021, 20:59:45 »
Actual Deskmat posted. GB soon  :D
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #13 on: Mon, 18 October 2021, 12:10:49 »
bumpy start but still looks pretty neat, gl
« Reply #14 on: Mon, 18 October 2021, 20:26:09 »
Thank you  :D
Re: [IC] Overkill Deskmat - GB Live!
« Reply #15 on: Wed, 20 October 2021, 08:03:29 »
GB is now live!  :D
« Last Edit: Mon, 15 November 2021, 20:28:01 by unimaginablypatzer »
Re: [IC] Overkill Deskmat - GB Last day Nov16 (GMT+8)
« Reply #16 on: Mon, 15 November 2021, 20:29:19 »
GB last day is today! Thank you to everyone who joined 🙏
