Author Topic: Keychron C2 upgrade  (Read 2008 times)
Offline CanguroGuro
Keychron C2 upgrade
« on: Mon, 06 September 2021, 07:26:38 »
Hi everyone!
I'm looking for a new keyboard. Right now I have a modded Keychron C2. I like it, but I'd like to upgrade to something better, and also switch to TKL. I couldn't find any keyboard that meets my needs (at least not in stock), so any help is appreciated.
These are the requirements:
- Traditional TKL format (I NEED the 6 keys above the arrow keys in the traditional format)
- Solid metal case (the whole case, not just the plate)
- Hot-swap PCB, supporting 5-pin switches (I don't want to trim my Tangies)
- Backlighting (ideally RGB so I can choose a color)
- Wired only (I don't want any batteries inside the keyboard)
The only keyboard I found that meets my needs is the Mode Eighty, which I like, but it's not in stock and I wouldn't pay a fortune to a reseller.
Any suggestion will be appreciated.
