Author Topic: [IC] Aster Ergo TKL with F13  (Read 32482 times)
Offline Jacki
Re: [IC] Aster Ergo TKL with F13
« Reply #50 on: Wed, 29 September 2021, 01:51:32 »
+240$ to get a brass weight.
[img width=267 height=120]https://i.imgur.com/in3VqH2.jpg[/img
Offline NightFox99
« Reply #51 on: Sat, 16 October 2021, 15:22:49 »
Like it very much BUT won't get if the brass weight version price is maintained that high. Plus what is that strange thing on the upper right side of the top plate ?
Offline ssatta
« Reply #52 on: Tue, 02 November 2021, 16:13:56 »
I would appreciate some more variety in plates, not just aluminum. Maybe something softer, POM or some other plastic?
Offline SirKhamenman
« Reply #53 on: Wed, 03 November 2021, 01:44:08 »
1. I agree with many comments here that the 2nd logo/icon that looks like discord logo is distracting and not needed
2. It's really expensive keyboard. +/- $650 that is a lot..
Offline treeleaf64
    • treeleaf64
« Reply #54 on: Wed, 03 November 2021, 10:09:40 »
Holy moly that's expensive
Too much 3D machining required, which takes a lot of time for machining.
Also current crazy raw material price is one of the reason of the high price too.
('Not made in China' is another reason for the price)
Can vouch for raw material price. seriously limits options . waiting for prices to go back down before pursuing copper /brass extension of project
How reliable can your voucher be considering you have ordered one (1) raw one(1)-off that was for yourself? Of course it's going to be expensive.
There exists a valuable tool: communication.
(Hint: I talked to the factory and got quotes, asked them, worked out solution, threw out solution b/c too expensive)
Insufferable
Everyone must pay the cat tax
Offline i luv chuletas
« Reply #55 on: Thu, 18 November 2021, 11:17:31 »
Any chance the PCB will support alps switches?
Offline less_blank
« Reply #56 on: Tue, 19 April 2022, 21:19:36 »
Bumping this thread to give it a little more visibility since I'd like to see this board hit MOQ. GB is currently live on https://bahmstudio.com/collections/all until April 30th.
edit: just saw they made a GB thread so this was probably unneccessary. :P
« Last Edit: Tue, 19 April 2022, 21:23:11 by less_blank »
« Reply #57 on: Fri, 13 May 2022, 13:52:36 »
fancy little board I really like it little pricey but still considering  :thumb:
