Author Topic: [IC] Aster Ergo TKL with F13  (Read 32478 times)
Offline jmSur
« on: Sat, 11 September 2021, 11:39:53 »
Aster Ergo TKL
Let me introduce an ergo TKL keyboard with a concept of stars and spaceship.
This Aster Ergo TKL is a series of 'Corenstellation', a split keyboard with 'Corne' layout.
BTW, we, Mt. Keyverest, have successfully run SEMO TKL Founder's Edition and Standard Edition GB recently.
All the GB participants gave testimonies of high quality and nice typing feel/sound of SEMO TKLs.
We will make Aster Ergo TKL with highest quality.
Ok, let's see the pics of this beautiful keyboard.
[GB Info]
- GB Period : 1st January 2022 ~ 31st January 2022
- Max Quantity : 300 Sets
- MOQ : 50 Sets
- Two version : Premium(with brass weight) and Standard(without weight)
- Prototypes will be made late October or early November this year
- Interest check form : https://forms.gle/Usx3bu4R5xvaqSxr6
[Specification]
- Typing Angle : 7 degrees
- Mounting Style : Gasket mounted (may be top mounted too)
- Weight : Premium 3.48 Kg / Standard 2.0 Kg (unbuilt and without PCB)
- Color :
   Top - Navy, Black +TBD (anodized)
   Bottom - Silver + TBD (anodized)
   Weight(for Premium version only) - Gold and Silver (paint coated)
- Badge : TBD - SS with engravings or Acryl/PC diffuser with engravings(RGB support)
- Includes
   Keyboard Top/Bottom (and Weight for Premium version)
   Aluminium Plate
   PCB (Solder)
   Gaskets
   Bumpons/Screws/Microfiber pouch/Package etc.
[Price]
- Estimated Price (NOT FIXED YET) :
   Standard version - below 650USD
   Premium version - below 890USD
You can check more info and progress on our discord server : https://discord.gg/WhtyrcQmHT
Thanks for watching this IC thread!
Offline dededecline
    • Linktree
Re: [IC] Aster Ergo TKL with F13
« Reply #1 on: Sat, 11 September 2021, 11:56:48 »
Really cool concept, though I'm not sure I understand where the Corne influence comes into play. It'd also help to have an exploded render showing the plate and gasket mounting.
Offline kameron
« Reply #2 on: Sat, 11 September 2021, 11:59:24 »
cool concept not a fan personally but glwic
Offline The0rigina1
  • fumoposting
« Reply #3 on: Sat, 11 September 2021, 12:04:42 »
Holy moly that's expensive
Offline _rubik
« Reply #4 on: Sat, 11 September 2021, 12:07:47 »
I’ve always wanted a board with this layout, but the execution isn’t exactly my taste. There are some things I could recommend, but for that price I don’t think it’s for me regardless
GLWIC
Offline herbologist
  • beige enjoyer. send help.
« Reply #5 on: Sat, 11 September 2021, 12:10:27 »
I'm wondering why there's a gb date before protos have arrived. You have no clue how your first protos are going to go. Definitely need to see exploded render. IC seems very premature. I'm not the hugest fan personally but at least it's something a little different.
Hope you take the feedback and put some more work into the ic once you have prototypes.
Offline jmSur
« Reply #6 on: Sat, 11 September 2021, 12:13:48 »
There is a keyboard named 'Cornestellation', and Aster Ergo TKL concept is same as Cornestellation. You can find this keyboard on my discord server.
The plate is not the final version.
Will run some simulation of the plate and revise it to get best typing feel.
There are total six gasket mounts. Will upload the pic later. Thanks.
Offline jmSur
« Reply #7 on: Sat, 11 September 2021, 12:14:14 »
Offline jmSur
« Reply #8 on: Sat, 11 September 2021, 12:16:11 »
Too much 3D machining required, which takes a lot of time for machining.
Also current crazy raw material price is one of the reason of the high price too.
('Not made in China' is another reason for the price)
« Last Edit: Sat, 11 September 2021, 12:26:29 by jmSur »
Offline jmSur
« Reply #9 on: Sat, 11 September 2021, 12:21:08 »
We make our keyboard by our own(we have our own factory, and even this is not our first keyboard but made lot lot lot of keyboards before). So, if modification is required(actually we do modify before we make the prototype), we can make revised version in a day(anodizing takes some more days but we can handle with the raw version too). Anyway, thanks for your suggestion.
« Last Edit: Sat, 11 September 2021, 12:25:32 by jmSur »
Offline treeleaf64
    • treeleaf64
« Reply #10 on: Sat, 11 September 2021, 13:29:55 »
Can vouch for raw material price. seriously limits options . waiting for prices to go back down before pursuing copper /brass extension of project
Everyone must pay the cat tax
Offline The0rigina1
  • fumoposting
« Reply #11 on: Sat, 11 September 2021, 13:36:23 »
Some more questions after re-reading the IC:
Will the brass weight be a through weight (both internal and external)?
Will there be an option of badge-less? (Not a big fan of the design)
Offline apexshikari
« Reply #12 on: Sat, 11 September 2021, 13:41:13 »
Looks fantastic! Look forward to the GB!
Offline jmSur
« Reply #13 on: Sat, 11 September 2021, 13:44:49 »
Yes, the brass weight goes through the bottom case. Both internal and external.
Also please leave suggestion on the IC form about the badge. will definitely consider badgeless design too.
Offline jmSur
« Reply #14 on: Sat, 11 September 2021, 13:45:23 »
Agreed. That's why I made two versions.
Offline jmSur
« Reply #15 on: Sat, 11 September 2021, 13:46:03 »
Thanks for your interest!
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #16 on: Sat, 11 September 2021, 13:50:03 »
How reliable can your voucher be considering you have ordered one (1) raw one(1)-off that was for yourself? Of course it's going to be expensive.
Offline jmSur
« Reply #17 on: Sat, 11 September 2021, 13:53:25 »
Please check the weight pics.
Offline ejewell89
  • 4ever Smol
« Reply #18 on: Sat, 11 September 2021, 21:28:59 »
i really like this.
Offline jmSur
« Reply #19 on: Sat, 11 September 2021, 23:58:32 »
i really like this.
Offline Sicowa
« Reply #20 on: Sun, 12 September 2021, 00:12:05 »
I really like this idea.
Would really like to see this come to fruition. very excited to see how your prototype comes out.
I would like to add is possibly changing the USB port to be more cohesive with your rear design as it feels very abrupt. Would also rather the badge above the arrow cluster to be an engraving instead.
Otherwise very interested in future updates. GLWIC
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline The0rigina1
  • fumoposting
« Reply #21 on: Sun, 12 September 2021, 02:23:00 »
Thank you.
Offline hottrout
  • I'd Hit Dat Key
« Reply #22 on: Sun, 12 September 2021, 03:56:47 »
I think your keyboard is more likely to come from the constellation of Virgo if you get what I am saying.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline L4ll1g470r
« Reply #23 on: Sun, 12 September 2021, 05:04:49 »
ISO support?
Offline jmSur
« Reply #24 on: Sun, 12 September 2021, 07:52:10 »
ISO support?
Does support ISO and splits(l r shift and bs etc)
Offline jmSur
« Reply #25 on: Sun, 12 September 2021, 07:53:02 »
Any idea how the usb port shall look like?
Offline jmSur
« Reply #26 on: Sun, 12 September 2021, 07:53:48 »
Sorry couldn't catch what you wanted to say.
Offline linell
« Reply #27 on: Sun, 12 September 2021, 08:34:49 »
The FLX Virgo is another ergo TKL
bro this a **** set, just be thankful you even getting 1 base running fr
Offline Surefoot
« Reply #28 on: Sun, 12 September 2021, 17:17:54 »
Well, of course, yes !
Very please with how the Semo turned out, so that one is a no-brainer.
Offline honeybee
« Reply #29 on: Sun, 12 September 2021, 18:47:21 »
+1 for badgeless. Looking for my first keyboard, I'd originally wanted a full size. I'd considered Odin on KBD Fans, but the badge killed it for me. I'm interested in this board regardless though.
Offline darthcapn
« Reply #30 on: Sun, 12 September 2021, 19:13:11 »
I too would like more info on where is the corne inspiration + the exploded render and a couple of renders with keycaps on would also be nice to have.
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline japancakes
« Reply #31 on: Mon, 13 September 2021, 01:10:29 »
Hoping for matching top/bottom case option instead of mixed.
Offline key_nes
« Reply #32 on: Mon, 13 September 2021, 01:41:15 »
I like how the typing angle! Nice concept overall. Just hope the price could be cheaper...
Offline i luv chuletas
« Reply #33 on: Mon, 13 September 2021, 07:39:26 »
Hmmm.. Really love this idea, and its reference too.
I would look into removing either the badge, or the discord-esque looking logo/engraving on the top right. With an already impressive looking layout, having both visual elements on the front as well only busies/muddies the visual language on the board.
My own suggestion would be to take the badge completely from the front, and instead use it as an engraving to replace the little logo up top. Another option could be to eliminate the little logo, and instead of a badge just engraving the constellation where the badge is currently at, cleaning up the look still.
Either way, VERY interested in this!
Offline Mr_BeastQuake
    • Reddit
« Reply #34 on: Mon, 13 September 2021, 08:52:08 »
Have a SEMO, like it. Will get one of these too. I’d like it if a solid color option was available in black or silver.
Offline honeybee
« Reply #35 on: Mon, 13 September 2021, 09:14:04 »
I hadn't even noticed the badge above the arrow keys, I'd confused that with the engraving you'd mentioned when I said "badge" in my earlier comment. I don't actually mind the badge, it's the engraving / "discord-esque" logo that I dislike.
Offline WillyWortel
« Reply #36 on: Wed, 15 September 2021, 09:20:23 »
Cool concept.
I love the layout, back and the USB cutout. The weight and engraving looks stunning. Personally, I don't mind badges when they are not standing out to much. I'm not sure if the angled front profile (wrest rest area) is to my taste.
Let's see where this goes.
    • Reddit
« Reply #37 on: Wed, 15 September 2021, 10:21:25 »
Also not a fan of badges. The SEMO stamp on the front was fine. I’m not sure I love the Little Dipper so much that I need a contrasted metal badge flying it’s flag.
Offline _rubik
« Reply #38 on: Wed, 15 September 2021, 10:47:54 »
Cool concept.
I'm with you. The badges are sign of uniqueness and personality of the designer. Almost a makers-mark. That's something which shouldn't be hidden IMO.
That front lip is what's bugging me (I think). Tricky to place. I looks good on traditional 1800 boards, but something about it here makes the angle feel exaggerated -- almost wedge-like.
« Reply #39 on: Wed, 15 September 2021, 15:28:58 »
I personally really dig the wedge-esque look the front has, it gives it a unique personality. That's something that I look for in every board (which is how I've built my collection out so far)
Regarding badges though, I get what you guys mean, but that's when I say it's better to pick one or the other. Having two logos/badges just detracts from the designers work, which should speak for itself without logos and all that.
That being said, I do dig the badge on top of the arrow clusters. The one on top though... it's rough. At least coupled with the badge, it's too much going on.
Gondo's/CK's Sagitarius is a victim of this too. The star constellation in the middle is a beautiful touch on a unique keyb, but then the CK cannon completely ruins the look by adding one element too many to the design.
All of this of course is more design philosophy than anything else lol
Still, really looking forward to this running. I've been wanting a layout like this for forever at this point lol, and this one looks to be a unique offering in that regard  :p
Offline dudewth
« Reply #40 on: Wed, 15 September 2021, 16:41:51 »
I like this a lot. I don't mine the details on the bottom and like that the top is relatively clean.
Offline honeybee
« Reply #41 on: Thu, 16 September 2021, 06:18:33 »
Fully agree, you've said it best.
Offline Danduil
« Reply #42 on: Sat, 18 September 2021, 11:11:47 »
I really dig the TKL Alice design and I think the board itself looks great. However, the price for this board is absolutely insane and I think there aren't enough features/adjustability to warrant such a price tag. I'm sure the group buy and IC will go great and there will be a lot of interest around it, but I can't see myself picking this one up unless there are some changes made (I.E. Hotswap).
Offline jmSur
« Reply #43 on: Sun, 26 September 2021, 21:57:42 »
I know about flx virgo, but it is also not the first ergo tkl. Also the layout is different from flx virgo. The design concept(not the layout) is from a split keyboard named Cornestellation.
Offline jmSur
« Reply #44 on: Sun, 26 September 2021, 21:59:17 »
You can vote some design options on my discord.
I am considering to change the badge design including the outer line.
Offline jmSur
« Reply #45 on: Sun, 26 September 2021, 22:02:26 »
The keyboard design(not the layout) is kind a series design which 'Cornestellation' is the first of this kind of look. I am going to make the prototype in late October or early November. Will update with keycaps on the prototype.
Offline WillyWortel
« Reply #46 on: Mon, 27 September 2021, 01:23:34 »
Would you consider maroon or aubergine purple (something that goes with GMK Bingsu)?
« Last Edit: Mon, 27 September 2021, 01:31:56 by WillyWortel »
Offline vi0till
« Reply #47 on: Mon, 27 September 2021, 04:16:05 »
Please aubergine purple.
Offline baka jiken
« Reply #48 on: Mon, 27 September 2021, 20:37:43 »
TKL Alice??? Holy hell. Sign me effing up :p
Offline severin
« Reply #49 on: Tue, 28 September 2021, 15:35:29 »
Looks beautiful, expensive, but beautiful
