Author Topic: So I am going to buy a Filco  (Read 5387 times)
Offline gun_sl1nger
« on: Wed, 01 September 2010, 00:38:29 »
I have 2 HHKBP2 and a Realforce 87u (which doesn't really get used) plus I have a Deck 82 in Red that I use for gaming.
Yet I feel I need another keyboard.
It needs to be quiet. I have a baby down the corridor (10 months old) and a wife that threatens to kill me should I wake said baby with incessant typing. Typing normally takes place on the Deck as I do that in between gaming when I get the chance (which is infrequent at best).
I really want a Cherry Blue Board but I know that Blue = Noise
I don't want Cherry Black. The Deck is Cherry Black and I want to try a different switch.
Any advice appreciated.
HHKB P2 Charcoal/Black
HHKB P2 White
Deck 82 \'Fire\'
Topre Realforce 87u Black
GHSS (Its in the mail)!
Offline Arc'xer
« Reply #1 on: Wed, 01 September 2010, 01:05:41 »
Browns?; tactile, non-clicky.
Though your Topre/HHKB should be quite aside from the "thocking" of the space bar. Maybe break out the 87U, you did say you don't use much.
Blues are hard to describe without being in person. A lot of times microphones amplify it noisily or amplify noises not normally heard. Loud for someone tapping them down all the way to the bottom is noticeable, but when typed on properly they aren't extreme though if your situation is that bad then the blues could echo through.
Offline ironman31
« Reply #2 on: Wed, 01 September 2010, 07:28:38 »
Although not as loud as blues, the Filco browns at least can be a tad loud if you bottom out. It seems like they are louder because of the metal plate. Not sure what the noise differences are between metal plate browns and pcb mounted.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline ch_123
« Reply #3 on: Wed, 01 September 2010, 07:34:12 »
Of course, the Topre keyboards you currently have are miles better than anything with browns.
Offline lmnop
« Reply #4 on: Wed, 01 September 2010, 08:01:24 »
Quote from: gun_sl1nger;218739
off topic.
There is no way to fix the problem on your current board, however depending on when you purchased it originally we may be able to work out an exchange for an Ice. Please email us at technicalsupport@deckkeyboards.com for further info.
if you purchased your Deck 82 Fire in 2009 you might be able to trade your Deck 82 Fire for a Deck 82 Ice because the controller on the Deck 82 Fire is bad.
« Last Edit: Wed, 01 September 2010, 08:13:48 by lmnop »
Offline ironman31
« Reply #5 on: Wed, 01 September 2010, 08:32:35 »
Quote from: ch_123;218778
That's why I bought a 55g one, if I didn't, it would be stealing too much brown time. :P
Keyboards:
Pointing Devices:
Offline elbowglue
« Reply #6 on: Wed, 01 September 2010, 09:20:31 »
Plate mounted blue cherrys such as the filco are hecka loud.  PCB mounted blue cherries (g80-3000LSCRC) are somewhat quieter, the bottomout noise is maybe 25% as loud, the click still clicks however.
You can always go brown cherries, again i would recommend PCB mounted brown cherries for noise purposes.  Consider the ricercar spos if you want a compact layout, or get the MX 11800 and cut part of it off like in my sig, "compaq 84u" link.
I prefer cherry browns to topres, I might be an odd duck, but I have sold the two topre boards I have owned.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline gun_sl1nger
« Reply #7 on: Wed, 01 September 2010, 18:46:13 »
Maybe I will just sell the Realforce 87u and get an 86u.
I forgot to mention that my wife will occasionally use the PC for work etc and can't type on an all black keyboard.
Is there some significant difference between the 87 and 86?
Is there much of a market for the 87u?
HHKB P2 White
Deck 82 \'Fire\'
Offline ch_123
« Reply #8 on: Wed, 01 September 2010, 19:02:57 »
Quote from: gun_sl1nger;218992
Did you get the all-55g or variable weight one?
Offline keyboardlover
« Reply #9 on: Wed, 01 September 2010, 20:05:19 »
I might be interested...
Offline gun_sl1nger
« Reply #10 on: Wed, 01 September 2010, 20:25:02 »
Variable weighted version
I'd trade it for an 86 if it is basically the same board.
HHKB P2 White
Deck 82 \'Fire\'
Offline panda-R
« Reply #11 on: Wed, 01 September 2010, 22:49:23 »
Quote from: ripster;218796
Or put your foot down and have that woman make you a sammich!
lolz... i like this option the best.
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
Offline gun_sl1nger
« Reply #12 on: Thu, 02 September 2010, 03:08:21 »
You probably have point there, but I got 3 hours sleep last night due to a crying baby so I may have missed it.
Do you still use the one (87u) you modified?
Also you have a lot of posts geekgirl.
I have only 27
« Last Edit: Thu, 02 September 2010, 03:15:35 by gun_sl1nger »
HHKB P2 White
Deck 82 \'Fire\'
Offline itlnstln
« Reply #13 on: Thu, 02 September 2010, 07:19:57 »
That's because he talks like a (geek) girl.
Offline WhiteRice
« Reply #14 on: Thu, 02 September 2010, 07:40:47 »
I think we should propagate the myth that ripster is a lady, to confuse new forum members for entertainment's sake.
Offline WhiteRice
« Reply #15 on: Thu, 02 September 2010, 10:10:33 »
Quote from: ripster;219142
Nobody has hit on my Avatar since I stuck this in my profile.
Anyway, there is only ONE GeekGirl.
I imagine droves of sweaty geeks sliding their fingers against the screen in hopes of something happening. xD
Offline gun_sl1nger
« Reply #16 on: Thu, 02 September 2010, 21:40:16 »
I was referring to the avatar. Which I am pretty sure is 'geekgirl'.
I have lurked a long time. Err that doesn't sound right, I meant loiter, nope that makes me sound like a miscreant.
Anyway you get the picture.
You do have a slippery spacebar though.
HHKB P2 White
Deck 82 \'Fire\'
woody
  •  Guest
« Reply #17 on: Fri, 03 September 2010, 05:56:56 »
That one.
________
california dispensaries
« Last Edit: Sat, 05 February 2011, 13:33:32 by woody »
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #18 on: Fri, 03 September 2010, 23:10:52 »
This reminds me, I seriously need to go to Maker Faire next year.  I keep forgetting it happens here.  I think I get distracted by the other cons in May.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
